Clifford AG4 Remote Start ?'s
Old Aug 30, 2002 | 02:04 PM
96BlackHB's Avatar
Default Clifford AG4 Remote Start ?'s
It will not remote start unless I hold down the clutch pedal. I e-mailed the guy I bought the AG4 from and asked him if I needed a relay or needed to tap a wire into the clutch switch and he responded:
"The AG 4 is designed already to work with a manual transmission. The way it works is you put the car in neutral then you put the unit in quickstart mode then open and close your doors and arm the system. the alarm then knows that you exited the vehicle and will remote start again as long as no one has disarmed and opened the door before trying to remote start."
Following his instructions it doesn't work.
What do I need to do to bypass the clutch switch?
Old Aug 30, 2002 | 04:21 PM
o_Rage_o's Avatar
Default Re: Clifford AG4 Remote Start ?'s (96BlackHB)
the clutch pedal bypass may not be hooked up correctly.
Your car won't start (factory) without the clutch being held down, in order to correct this, you need to short the clutch switch (found at clutch pedal..up top..reach up there, its the higher one, not the first one..)
Not sure about the ag4, but it might have a wire specifically made to tap this.
-Rage
Old Aug 31, 2002 | 04:58 AM
96BlackHB's Avatar
Default Re: Clifford AG4 Remote Start ?'s (o_Rage_o)
there was not a wire that was directly called out for the clutch in the install guide
Old Aug 31, 2002 | 05:04 PM
philly-O's Avatar
make sure you are getting the vechicle's crank wire after the clutch relay.
Old Sep 20, 2002 | 11:53 AM
integra-modder's Avatar
Default Re: Clifford AG4 Remote Start ?'s (peichie)
goto page 10 of the install manual, if you dont have it, email mail and ill scan it for you, you need a relay
EGed up from the seat up
Apr 6, 2011 06:33 PM
D16SiHatch
Audio / Security / Video
Mar 31, 2009 06:12 AM
neonoodle
34
May 29, 2008 09:14 AM
brickonwheels
Jun 9, 2005 01:33 PM
brickonwheels
Jun 7, 2005 08:44 AM
