obd2 jdm d15b into 91 crx hf
Old Oct 30, 2009 | 11:13 PM
dmeiser0001's Avatar
Default obd2 jdm d15b into 91 crx hf
Alright i ordered a obd1 d15b and the motor i recieved was complete garbage, so the company replaced the motor and the replacement is a obd2 d15b. I'm completely tired with dealing with this company so I took the motor knowing that it isn't to much different than the obd1 version motor. But now I've ran into a small problem with the distributor. I have a obd1 d16z6 distributor and the mounting holes do not line up, does anyone know what usdm obd1 distributor I could use that would mount correctly to this motor.
Heres my current setup.
obd2 d15b
obd0 to obd1 jumper harness, completely wired in correctly
p28 ecu
Any suggestions would be greatly appreciated.
I also wanted to know if there is a diagram for wiring up vtec because of the different vtec setup than the obd1 version motor.
Old Oct 30, 2009 | 11:15 PM
Default Re: obd2 jdm d15b into 91 crx hf
i will also mention i'm running a obd1 intake manifold and a resister box
Old Oct 31, 2009 | 07:31 AM
ttt need help
4dr_eg
Oct 18, 2013 01:20 AM
tianporn
Dec 12, 2005 11:24 AM
1man
Jul 21, 2003 11:45 AM
Civic
Jun 7, 2003 08:55 AM
