Signal switch/headlight problem. please help me
Old Oct 30, 2009 | 10:32 PM
Etorres325's Avatar
Default Signal switch/headlight problem. please help me
Thanks ahead for the Help.
So, i just bough myself an EK hatch, Everything works fine, I just have a minor electrical problem with the headlight/turn signal switch.
Problem. The lights work and everything, when i turn the switch to the first click the cluster lights up and the signal lights light up. When i turn it all the way, the headlights come on(as normal) but the cluster turns off.
When i turn it right between the 1st and 2nd click the headlight and cluster light up, but then occasionally turn off due to it not being the proper spot for the switch.
Im thinking the contacts inside the switch just need to be cleaned. I was just wondering how i would go about doing that?
Can i be pointed in the direction of a thread if there is one already?
Thanks for reading/Help.
Old Oct 31, 2009 | 06:06 AM
Former User's Avatar
Default Re: Signal switch/headlight problem. please help me
HT member Danomatic93 has posted a DIY thread.
redheadsSI
Jan 29, 2010 06:08 AM
Etorres325
Nov 2, 2009 06:29 PM
Etorres325
Lighting
Oct 30, 2009 11:39 PM
99delsol
Sep 14, 2006 08:01 PM
MugenHonda
May 30, 2005 08:29 AM
