WI - complete ls-vtec
Brand new build never used 0 miles on it, fully built All motor, Top to bottom expected to make 240-260 to the wheels. No extra building required ready to swap and tune.i have reciept for all the work from start to finish.need money to go back to school so my loss your gainfor fast respond call my cell 414-731-2033 motor is located in milwakee serious intrested only and dont waste my time thanks.(not parting out so dont ask) 5k obo
Block
- 85.5mm sleeved b18b block from RS Machine.
-Blueprinted and Balanced
-balanced crank
-balanced forged Ultralite Probe rods, retanged for type R rod bearings
-brand new oem crank bearings, brand new oem type r rod bearings
-custom 5.5cc Weisco pistons (calculated for 12.8 compression)
-Type r oil pump
-Arp head bolts
-Cometic gasket
-all hardwared & plumbed for b20vtec
Head
-99 b16
-Pure Tuning Spec C Port job (one stage before full blown drag) …305cfm (papers to prove it)
-Almost identical porting as Mike’s 11 second allmotor hatch at Kingmortosports
-Supertech .5mm oversized intake valves
-Standard Supertech exhaust valves
-Supertech 1002d valve springs
-Crower Chromoly retainers
-Skunk Pro 2 cam shafts
-Skunk Pro 2 cam gears
-IB ported Type R intake manifold
-70mm TB
-RC 550 cc injectors
-XS fuel regulator
-oem distributor & wires
-Hytech bigtube stainless steel replica header
Trans
-JDM type R 4.785 lsd
-Act 12lb chromoly flywheel
-Act HD pressure plate
-Act 6 puck spring disc
Block
-balanced crank
-Type r oil pump
-Arp head bolts
-Cometic gasket
Head
-99 b16
-70mm TB
-XS fuel regulator
Trans
Your Name
Jul 27, 2008 05:03 PM
