Busted tranny case want to swap B16 internals into LS...Sleeving?
I bottomed out a few days ago and I busted my case. I am low on funds, so I decided to pick up cheap cable LS tranny and I would like to swap the case.
Is there a write-up anywhere on this?
I keep reading that I need to "sleeve the bearings" and I am not sure what this refers to.
This is for a JDM EF9 B16 tranny.
Thanks in advance!
Thanks in advance!
Save yourself a headache and 2 bad trannys and just use the LS trans then have a trans builder do the B16 for you sometime later. Mainshaft needs to be shimmed and the tools required to do so don't fit with low funds.
