Need Insight On This Turbo Kit
Old Oct 30, 2009 | 02:51 PM
EnVeedH22a's Avatar
Default Need Insight On This Turbo Kit
I want to turbo my lude but i am short on cash by a longshot to get a decent setup. And i highly doubt i will ever boost over 8-9 lbs, i just want a some extra pep. I was just wanting some imput on this turbo kit i saw on ebay, and i know ebay isnt the best place to buy anything, but once again i am low on fundage and this caught my eye and was just wanting an expert opinion on this setup.
http://cgi.ebay.com/ebaymotors/HONDA...Q5fAccessories
^^^There is the link to the kit^^^
Old Oct 30, 2009 | 03:31 PM
EnVeedH22a's Avatar
Default Re: Need Insight On This Turbo Kit
bumpage
Old Oct 30, 2009 | 03:47 PM
NirVTEC's Avatar
Then you have no business boosting your car........
Let me ask this; If you buy that kit, boost your car, and pop your motor.......Then what? Bus rides or bumming rides....take your pick.
Old Oct 30, 2009 | 03:50 PM
thiskid0001's Avatar
ebay turbo = future problems for your car lol u decide
Old Oct 30, 2009 | 03:51 PM
NirVTEC's Avatar
Originally Posted by thiskid0001
ebay turbo+low fundage = future problems for your car lol u decide
FIXED
Old Oct 30, 2009 | 03:53 PM
EnVeedH22a's Avatar
thats what i was afraid of. can u tell my why? why it would have a better chance of popping my motor over the more expensive kits?
Old Oct 30, 2009 | 03:57 PM
NirVTEC's Avatar
Actually.....that wasn't my original point. You can barely afford a turbo kit, whats the plan if you pop your motor? Crapy wastegate lets you overboost!?
Now, when you have the $$$ to rebuild/repair/replace your motor.....Boost away!
Same advice I give people about Nitrous....and those kits start at $2-300 used.
Old Oct 30, 2009 | 04:08 PM
EnVeedH22a's Avatar
so the kit itself isnt bad? the manifold looky pretty shitty and i was ganna get a different one, and i could get a new wastgate for saftey. and i wasnt planning on boosting much at all, i would be happy with 6-7 lbs.
And i have thought about nitrous too, i just want a lil more go. And i have had nitrous on another car b4 this one so i do have some experience with N2O. You think that would be a safer bet? I would have it tuned for the nitrous.
Old Oct 30, 2009 | 04:11 PM
NirVTEC's Avatar
6-7psi VS 75 shot is pure Nitrous WIN!
I have driven an H22@8psi and it wasn't even close to my H22@75shot
IMO its the difference between a high12 setup and a mid-high13 setup.
I can't view ebay @ work.......
Old Oct 30, 2009 | 04:14 PM
EnVeedH22a's Avatar
the button it is then. lol, This is why i love you guys. Thanks alot.
and i can copy and paste the whole page so u can read about the whole setup and tell me your thoughts. i would appreciate it.
Old Oct 30, 2009 | 04:15 PM
EnVeedH22a's Avatar
# T3/T4 TURBO CHARGER:
# Stage III Turbocharger.
# Oil Cooled Only!
# Standard T3 4 Bolt Inlet Flange, Designed to Fit most Aftermarket Manfiolds and OEM T3 Manfolds.
# 5 Psi to 20 psi Peak Power performance Output Capability.
# Designed with Standard 5 blot T3 Flange
# Includes internal wastegate port (option to use)
# Designed with 35/38/44 mm Wastegate Port.
# Compressor Specs: 3'' compressor inlet, 2.130'' inducer, 2.755'' major, 2'' compressor outlet, T04B/T4 type compressor houseing, compressor .49 A.R, compressor .50 Trim, 8 Blade Type Turbine.
# Turbine Specs: T3 Type Turbine Flange, T3 5 Bolt Flange, Turbine .57 A.R, 2.205'' Minor and 2.570" Major Propellar, T3 Turbine housing, 2.274" outlet, 12 Blade Type Turbine.
# Can Manifold to use External Wastegate or Internal wastegate.
# Suggested for 1.6L to 3.2L engine up to 150-400HP.
# INTERCOOLER:
# Size : 28" x8" x 2.5" With 2.5' Inch Inlet/Outlet.
# Low Pressure Drop - Large Cooling Area - Easy Install - Tube And Fin Style Intercooler.
# Made from all TIG welded t-6061 aluminum (increase 10-20 HP)
# psi drop under 0.2. other intercoolers usually drop 10 psi, while some are more.
# New style, more efficient than stock intercoolers
# ALUMINUM PIPING KIT:
# 100% Brand new ,Made of 6061 Aluminum. 2.5'' inch diameter piping kit with high quality silicone couplers and t-bolt clamps. The coupler will not split easily+ the clamps will not between the pipe and the couplers, it was 4 ply layer reinforced, not the cheap intake coupler. Mandrel bend for high flow and high horse power and better turbo response power. Same as picture, come with 12x pipie ( 2x straight, 4x 6'' 90 degrees, 6x 13'' degrees ). 24 x stainless t-bolt clamps, 4 x 90 degrees elbow, and 8 x straight silicon hose. Note*: this is not the cheap stuff like all the ebay seller, make high quality, and most complete piping kit.Some Cutting And Modification Required!
# JDM H-SERIES H22/H22A TURBO CAST MANIFOLD:
# 1 Piece cast iron turbo manifold for PRELUDE H22/H22A engine.
# High Resistance to heat - made to last - cast iron turbo manifold.
# Uses t3/t4 flanged turbos
# Come with everything bolts, nuts and screws and flanges
# Direct bolt-on to all the PRELUDE H22/H22A engines.
# Work with 35/38/44 mm wastegate flanges included
# Life time warranty.
# 38MM WASTEGATE :
# All Stainless Steel hardware, Mating weld flanges are 304L.
# 2 Bolt Flange set up for turbo applications
# Incoel base housing with forged stainless steel valves construction.
# Wled-on flanges are include with every kit.
# High temperature silicone reinforced actuator diaphragm.
# Spring Size is 7 PSI.
# BOOST CONTROLLER:
# Allows Adjustable Boost PSI Settings, Light Weight Design To Be Mount Under The Hood. Hardware Is Included.
# Manually Control turbo boost up to 1-30 PSI.
# Made from billet aluminum
# Mounting bracket , hose and all fitting hardware included
# OIL RETURN LINE:
100% BRAND NEW, HIGH QUALITY ALUMINUM.THE RETURN LINE IS 17 INCH LENGTH.
HELPS CIRCULATE OIL FROM THE TURBO TO THE OIL PAN, WORKS ON METAL OIL OANS ONLY.
# OIL FEED LINE:
# 100% Brand New, High Quality, Never Been Used Or Installed!
# The Oil Feeding Flange has Restriction build in, offers proper Oil Feeding to the turbocharger.
# The Length Is 37 Inch.
# FUEL PRESSURE REGULATOR:
# 100% Brand New in the box and high quality.
# JDM adjustable fuel pressure regulator (FPR)
# Make by aluminum . light-weight design, long lasting.
# Package come with all the hard wares and hoses
# Increse fuel delivery by rasing pressure ( increase 5-10)
# OIL CATCN CAN TANK:
# Make out of T6061 Aircraft Lightweight.
# Increase Horsepower and prolongs your engine life.
# Dimensions: length: 7'' X with: 2.5''
# SLIM RADIATOR FAN:
# 100% Brand New , Really High Quality.
# Light-weight Design, and More Durable Than Factory Fan When Increasing Engine Cooling Performance.
# Size: 12'', 2.5'' Thickness, 1250 CFM, 2100 RPM.
# TYPE-S BLOW OFF VALVE BOV+ADAPTER PIPE:
# CNC Billet Aluminum, Dual Stage Handle, High Boost Power,Easy Mount Piping Set Included For Bolt-On.Including Bov Blow Off Value Flange.
# Fast Fesponse One For Low And High Boost Pressure.
That is all the specs it gives me on the ebay kit.
Old Oct 30, 2009 | 04:18 PM
NirVTEC's Avatar
Buy a Nitrous Express GEN2X kit /done
Old Oct 30, 2009 | 04:19 PM
EnVeedH22a's Avatar
but nitrous would be the cheaper route, the only thing is with the nitrous that i ALWAYS get caught with my bottle empty. someone is talkin **** in thier Ford NuttStain (Mustang) and my bottle would be empty. but my car now has no problems hanging with mustangs like it sitts, i just want to smoke them and smile.
Old Oct 30, 2009 | 04:25 PM
EnVeedH22a's Avatar
ok , sounds like a plan to me. what kinda numbers do u think i could put down? all my mods are listed in my sig. and what numbers do u think i am putting down now? and i know this will be a guesstimation.
Old Oct 30, 2009 | 04:37 PM
NirVTEC's Avatar
A JDM H22A with i/e on the dyno I use probably wouldn't break 160whp.[Its a Dyno Dynamics though]
2-20# bottles in the trunk. Problem solved.
Old Oct 30, 2009 | 06:22 PM
EnVeedH22a's Avatar
lol, ya. how much is that NX kit you were talkin about? and how big is the bottles?
I really want to do it with electric bottle openers and have it where my spare is in the trunk so i can be sneaky with it. lol I hated having to get out, pop the trunk, and open the valve in my other car, everyone was like, 0o0o0o0 what r u doin? baby need his bottle? lol. And it deffinatley sucked when i got caught at a stoplight with it off.
Old Oct 30, 2009 | 08:26 PM
EnVeedH22a's Avatar
bump
Old Oct 31, 2009 | 04:10 AM
Apex1972's Avatar
http://www.veoh.com/browse/videos/ca...112248bREQ2h9t
Old Oct 31, 2009 | 06:26 AM
NirVTEC's Avatar
IIRC the kit is ~$1,000 NEW. It comes with the Purge and Bottle warmer. If you opt to buy bottle openers, DO NOT buy the motorized valve opener type. The Solenoid type is much better. Kit comes with a 10# bottle, but you may be able to pay for an upgrade to a 15 or 20. You can always find used 20#'ers on Muscle Car Forums.
dc101
Sep 30, 2011 06:38 AM
andre mendes
Jul 8, 2011 12:26 PM
EMinh1
May 3, 2011 05:05 PM
accord03coupe
Feb 13, 2007 09:36 AM
