Blows oil from dipstick tube under boost
I have a 1995 honda civic ex with an 94 acura ls in it. when it comes into boost it blows oil from dipstick under boost. i have changed pvc valve and it still does it. any ideas what it could be?
Rings are going bad. You are experiencing blow by(boost leaking past the rings) or for some reason you have a charge pipe connected to your valve cover.
I recently saw a Mitsubishi Eclipse spraying out oil from the dip stick tube. His turbo ended up being shot (that's putting it lightly). So checking the play in your turbo might be something to quickly check.
jdmtiiteyo
Jan 1, 2008 06:40 PM
Integra GSR 95
Jul 20, 2005 11:58 AM
1996GsrVtec
Apr 15, 2002 08:07 PM
