HALP: 94 Hatch has been sitting for about a year... now its overheating!
Old Oct 30, 2009 | 10:37 AM
j0nb0y22's Avatar
Default HALP: 94 Hatch has been sitting for about a year... now its overheating!
I fired up my Civic that had been in the body shop for about a year (don't ask lol) and all seemed well at first (The car had no coolant when I picked it up but I added that before I started it), then the temp gauge started rising and didn't stop. It was pinned on 'H' and the car started smoking (white). I pulled over right away, now the car is sitting. What should I check first?
Old Oct 30, 2009 | 11:36 AM
bar'dh22's Avatar
Default Re: HALP: 94 Hatch has been sitting for about a year... now its overheating!
head gasket
Old Oct 30, 2009 | 02:38 PM
Former User's Avatar
Yeah, white smoke suggests burning coolant in the cylinders (=blown head gasket).
Does the radiator fan run?
In the meantime, replace the thermostat and radiator cap, and then try bleeding the cooling system:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below (hint: the bleed bolt is located where the upper radiator hose connects to the engine):
Jonathen Lee
Oct 8, 2018 02:18 AM
Omega Blaze
Aug 20, 2016 01:48 PM
hondaluv345
10
Sep 6, 2013 05:47 AM
thewrai6th
Feb 8, 2013 02:11 PM
D C 5
Sep 16, 2005 11:00 AM
