TO THOSE OUT THYERE WITH A DOHC ZC...
Old Oct 30, 2009 | 07:10 AM
JDMefHATCH7's Avatar
Default TO THOSE OUT THYERE WITH A DOHC ZC...
anybody knows if a PR4 ECU is compatible with a DOHC ZC ?
i did my research but found that the ECUS that go with DOHC ZCs are
PM7
PG7
PM6
and that PR4 ecus are from either a 1990-1993 Integra LS/GS(DA) with OBD0
and in some cases PR4s came OBD2 with LS/GS/RS (B18B) all being 1.8 motors in my head it doesnt make sense that the PR4 works with a ZC
but if anyone that has or had DOHC ZC can answer this question for me i'd really appreciate it
Old Oct 30, 2009 | 08:45 AM
kamui427's Avatar
Default Re: TO THOSE OUT THYERE WITH A DOHC ZC...
i have a Dohc Zc motor in my 91 hatch si and my pm6 computer that came with the car runs my zc motor just fine ive never had a problem out of it.
Old Oct 30, 2009 | 09:09 AM
''Simon'''s Avatar
i did a swap for one my buddys an he bout a pr4 an it runs great.
Old Oct 30, 2009 | 09:16 AM
jlicrx's Avatar
the OBD0 PR4 ECU will run the DOHC ZC, just not as well as the PM7 or PG7 - PM6 will also not run as well as the PM7 or PG7 due to having lower rpm fuel cut-off - both PR4 and PM6 have fuel cut-off at about 400 rpm lower than the PM7 and PG7
Old Oct 30, 2009 | 09:17 AM
efjones9's Avatar
any obd0 non vtec will work. but honda made specific ecu's for a reason
Old Oct 30, 2009 | 09:29 AM
isnt the PR4 1.8 for LS and GS integras?
i bought a crx with a poorly done DOHC ZC swap and its not running well seems like timing isnt right and when i was removing the carpet there was a loose PR4 thats why i asked because this might be the problem but im going to try and find a PM6 or a PG7 because unfortunately the pm7 is hard to find unless you buy a jdm swap
anybody else with bad PR4 experiences? let me know..
Old Oct 30, 2009 | 10:57 AM
jlicrx's Avatar
yes - 90-91 with B18A1 engine
Old Oct 30, 2009 | 11:34 AM
BiG ChOr!Zo's Avatar
i ran a pm7 on my old zc dohc setup and it ran perfecto...!!!
Old Oct 30, 2009 | 01:43 PM
24TEN's Avatar
PHANTOM MENACE
obviously LOL
I ran a PR4 on my DOHC ZC for a time, it ran slightly different (sluggish). Only slightly noticeable, but it ran.
Old Oct 30, 2009 | 02:28 PM
exactly so they are not ecus for a 1.6 DOHC...
im going to upload a video of the engine so you guys can see and let me know what yall think..
Old Oct 30, 2009 | 04:17 PM
bunnyhatch93's Avatar
I'm not sure of the ecu numbers but i had a 89 integra us ecu runing my zc and it ran like a champ!
Old Oct 30, 2009 | 04:18 PM
89 integra ecu is pg7...!!!
Old Oct 30, 2009 | 05:07 PM
yeah i know but a 89 very hard to find
if anybody got a PM7 PM6 or PG7 ECU let me know..
heres a little vid of the engine..
kinda gay but if anybodys ever had trouble or might know what can be causing this feel free to post thanks
Old Oct 30, 2009 | 05:27 PM
you guys might want to skip to 2:10...
Old Oct 30, 2009 | 05:50 PM
brownsEF's Avatar
the pm7 pretty good but it cuts off at 115
Old Oct 30, 2009 | 05:58 PM
jbrokos307's Avatar
i have a zdyne pm6 its amazing very pricey but my redline is set at 8300 wich is way beyond a zc redline so have to be carful lol i just spun my bearings i changing my motors out tomarow do u have cams in it or is that just the rough idle i hear nice headers i didnt know greddy made headers for zc's back in the day
Old Oct 30, 2009 | 07:06 PM
bump before going to sleep
take a look at the vid!
BlueRex1020
Oct 11, 2006 05:03 PM
LorenGeist
24
Aug 18, 2004 05:43 AM
LorenGeist
Aug 14, 2004 03:01 PM
ZColeon
Jan 14, 2002 06:51 PM
