need to know wats wrong wit my h22?
aight my other problem was fixed but now i keep going through clutches....i need to know the best clutch for an h2b....i heard that the unsprung is the best so i wanna hear some opinons
Does it idle bad?
Did the car come with a H in it?
Is your egr valve clean? unplug the vac line see if that helps at idle (never leave unplug when not testing)
Is you ignition timing set right?
unsprung hub is more for race than street, it mean to be engaged more like an on/off switch. If you do street driving you probably have to let the clutch slip a lot to start moving smoothly which is probably wearing out you clutch quick.
