95 civic wont start
Old Oct 29, 2009 | 11:14 PM
IGuess's Avatar
Default 95 civic wont start
Went to work and car was fine. Got out and went to leave and car would not start. My batt is fine. Just want some ideas so I know what to look at in morning. Im thinking it may be whatever gets pushed down when u push clutch to start car. Let me know what you think. Thanks for your time.
Old Oct 31, 2009 | 12:12 PM
norbi_cvc's Avatar
New User
Default Re: 95 civic wont start
I would check these:
main relay (if the engine tries to start)
distributor (distributor cap and rotor cleaning, the ignition coil measure or ignition module change) If theres no spark.
If all the above are good, than the starter motor need to be checked.
Old Oct 31, 2009 | 05:24 PM
Former User's Avatar
I assume the starter doesn't crank the engine when you turn the key to ON(III). As you mention, check the starter switch located at the top of the clutch pedal. It may have broken. If the switch is fine, have the starter tested.
Old Nov 1, 2009 | 07:41 PM
IGuess's Avatar
Thanks man. This was the problem. All fixed.
limerence
Jan 13, 2012 10:45 PM
ftrms
15
Dec 22, 2010 04:05 PM
stl eh2
Dec 3, 2009 10:07 AM
curiousgpnoy
Jun 25, 2003 08:43 AM
scrap1ngsr
Mar 4, 2003 11:59 AM
