balance shaft...
Old Oct 29, 2009 | 09:21 PM
LobeSex's Avatar
Default balance shaft...
ok so i removed my oil pump a week or 2ago and relized the rear bs tooth(that locks the gear in place) is sheared off dont ask how but it did so i was wondering it i just remove the bs belt how would that affect my motor?
Old Oct 29, 2009 | 10:23 PM
jlude90's Avatar
Default Re: balance shaft...
be fine.
Old Oct 30, 2009 | 06:25 AM
PirateMcFred's Avatar
It'll vibrate more. That's about it.
Old Oct 30, 2009 | 06:51 AM
92civlude's Avatar
I left a balancer belt off, (at the customers request). He claimed an increase in MPG and more mid RPM throttle response!
Old Oct 30, 2009 | 08:01 PM
LobeSex's Avatar
lol with my setup ill need all the mpg i can get lol although i doubt that will happen but thanx guys
Old Oct 30, 2009 | 09:43 PM
fastlane2's Avatar
There is a kit you buy to eliminate this all together.
Old Jul 3, 2010 | 06:08 PM
LobeSex's Avatar
ok so gona FINALLY BE TAKING THE LUDE TO GET FIXED...so u guys are sure if i leave the bs in there with the gear unattached which would leave the bs just loose in the block it will be absolutely fine...i will b taking it to the shop on monday so i would greatly appriciate some more input on this b4 then thanx in advance
Old Jul 4, 2010 | 11:15 AM
LobeSex's Avatar
BUMPP!!! 7th post!!!
Old Jul 4, 2010 | 11:48 AM
street_ride14's Avatar
yes, you'll be fine without the Balance-Shaft belt. Some engines did not even come with balancer shafts from the factory, they are there soley for driver/passenger comfort against engine vibrations. Leaving the actual shafts in the motor while taking off the belt is fine.
Old Jul 4, 2010 | 12:14 PM
LobeSex's Avatar
alright its all ur fault if something happend's to my motor then lmao jk thanks boss
daymkimchee
Nov 30, 2009 11:34 PM
1sickef9
Nov 24, 2009 07:18 AM
Dravenm4
Feb 14, 2009 02:18 PM
Nathan007
Aug 23, 2007 05:33 PM
EGmikeH22
Jul 31, 2005 04:53 PM
