13" VX wheel on Integra 1994-2001 and 1999-2000 Civic SI
I tried searching a few times, and never came with a exact answer with someone having tried it.
Well I picked up a set of 13" Honda VX wheels , To try them on the Integra 1994-2001 and they do NOT fit, ( wheel would need more offset )
And also test fitted it on a 1999 - 2000 Civic Si ( Canadian SiR ) and also DO NOT FIT.
And as the Acura 1.6 EL has the Civic Si ( canadian SiR ) front brakes They DO NOT FIT either ( also test fitted them ).
A shame because I wanted to run the 13" as a daily .
I personally Did not test fit them on Any other cars, those 3 above Im 100% sure As I tested them.
Hope that helps any one else looking for the information.
tags:
Will VX wheels fit my integra - Fit my civic SI SIR
tags:
I think 14" is about the smallest you can get over Integra brakes, unless the wheel was specifically designed to go over brakes that large. For example, Civic HX 14" wheels can fit with spacers.
I think a 15mm spacer would do the trick, but then you need new wheel studs.
I wanted a nice light weight - cheap set of wheels for the car. Got to max the mpg's
You are correct, Though a buddy had a set of keizer wheels ( im memory serves me right they are custom made) years ago, 13x8 or x 9 for his R compounds on an integra and it fit . ( but it had super low offset ) .
HX wheels only need 1/8" spacers or do like we did back in the day and grind that much off the outer portion of the caliper
