wiring/dizzy issues
Old Oct 29, 2009 | 05:04 PM
16yroldekownr's Avatar
Default wiring/dizzy issues
I've got an '89 CRX Si with a obd0 to obd1 jumper harness (DIY special) PR4 ecu. The car now has in it a b18b1.
first thing is the car has not been started(due to this problem) and the distributor is HOT, with the dizzy being plugged in i checked to see which wires were getting power through them and the only one that had power running through it was the Ign. Output(black w/yellow strip)
now with the dizzy cap off i checked to see what was getting power also and two wires next to the coil pack i believe was getting power.(not sure if only one is suppose to be getting power.)
the motor will turn but will not start.(obviously)
if anyone can help me WITHOUT giving me a hard time i really appriciate it.
i'm not sure if i'm lacking information but just let me know please.
-Terrance
Old Oct 29, 2009 | 05:31 PM
Marcos Barrios's Avatar
Default Re: wiring/dizzy issues
okay with your jumper harness did you get the plugs for your dizzy or did you just cut them? to switch your round plugs for the squared ones
if you got the plugs with your jumper harness you should be okay
it could be that you just have a bad dizzy
if you have any friends with the same set up as you
you could try useing there dizzy to see if that helps
Old Oct 29, 2009 | 05:54 PM
i looked up the wiring colors for the obd0 Si harness and the obd1 LS harness and all the colors matched so all i did was switched the plugs...
Old Oct 30, 2009 | 06:45 AM
anyone?
Old Oct 31, 2009 | 04:46 PM
no one can give me any other suggestions or help of some sort? searching has done nothing other than give me info on other things.
Old Oct 31, 2009 | 08:21 PM
frankiebseries's Avatar
try switching the white wire with the other white one that causes the dizzy not to give spark
Old Oct 31, 2009 | 09:08 PM
schock3's Avatar
ive seen articles on this in the diy section
Old Nov 1, 2009 | 03:47 PM
ive searched all over for this crap.
Old Nov 1, 2009 | 03:57 PM
hatchet_honda's Avatar
theres 2 white wires... ones larger than the other. try and swap the around. worth a shot
Old Nov 2, 2009 | 09:32 AM
located on the dizzy harness or what?
Old Nov 2, 2009 | 03:46 PM
91b17a1DxH/b's Avatar
Check all your grounds as well does it turn over? does it have fuel?
Old Nov 3, 2009 | 08:49 AM
yea its on the dizzy plug.
Old Nov 3, 2009 | 07:07 PM
ok, i switched the two white wires and it's still not turning over. the car will turn but just won't start, it is getting fuel also.
Old Nov 4, 2009 | 04:36 PM
help
CivCruise
Sep 10, 2009 07:49 AM
JDMej1Civic
Mar 30, 2005 06:04 AM
SOHCEK-Turbo
11
Mar 6, 2005 09:32 AM
ICeDoUt
May 28, 2003 10:14 AM
