Did some work on the 4 door this weekend
SORRY FOR THE BIG PICS!!
This is when i bought it a few weeks ago, she is still messy but Im so excited to get it running and get it back to stock look!
i went to the junk yard and autozone this weekend and got a few things
needed new clutch
Needed a flywheel after the clutch spring went on a killing spree
FLYWHEEL BOLTS damnn
new gas door
CRAFTSMAN kind'a guy
New master cylinder
The head was real clean for having 200k+
Head Gasket rip off
Block
Sorry for the pics being so big, but my plans are to make it run perfect for a bit, then the body work is coming VERY SOON, i will have a SICK suspension soon enough and i will do some small head swap to make it vtec, then I want some nice 15z!!!
needed new clutch
new gas door
New master cylinder
Head Gasket rip off
Block
im only getting it to drive for right now, then i will do either a head or complete swap, my buddy might be doing something with his si, so I might get the MPFI set.
The valve train looks like it belongs back in the bronze age lol. What kind of pad did you use to remove the gasket off the head? Looks like some good progress
ya the MC is new, i put it on the took it off, and back on again, I never used duralast but its a limited lifetime, and a few of my friends say they work just fine, $150 for clutch kit and $65 for brand new oem flywheel.
Not bad! I remember buying an OEM clutch one for my wife's old car but surprisingly it was a little bit less than $200.
Good luck with the project!
Im not sure the type, my step dad has them, but when i get back to the house i will see, they are like a soft semi stiff cleaning pad, works GREAT.
I hope to get it on the road sunday, i need to get all new ball joints, tie rods pads rotors, i just need to put the intake and exhaust mannifolds on, dizzy..sensors...bumper and hopefully should be good for the time being, but I so want this 4 door to be a BIG project!
i will put more pics up when i get sum more done.
bit of advise, buy a head gasket for a z6 or a y8. will save you time and energy in the long run. the graphite ones SUCK. i'm currently using a y8 h/g on my d15b1 and i've had no problems with the gasket.
car looks NICE, i've kind of grown a soft spot for the chocolate brown interior.
I got it for $580, it started but it didnt go into gear. i just need to get some ball joints put on it 2morrow and it should be driving.
good advice, im only using this gasket for a few... i plan on getting a vtec head for it shortly and then i shall get a diff head gasket.
whats wrong with the graphite ones, if u dont mind me asking. Weak?
Yikes... if you go metal head gasket, be sure to check the head and the block and make sure they are straight. If they are not, then get them milled... or just go with the stock gasket.
i find that the metal head gaskets are easyer to work with, plus they are re usable. you don't have the massive dirty clean up to worry about with them, unlike the graphite gaskets
Thanks guys, Today me and my brother did sum more work on the 4door, put new balljoints in and re connected everything, oil, plugs and wires went in, and when we had everything ready to start it up... we ran into a small problem with... we think is some wires leading to the dizzy, when i went to crank it over it would make a loud BUZZING noise and the check engine light came on, but if my bro would tweak the wires around the noise would stop, but we lost day light and he is going to see what it is in the morning, ANYONE HAVE ANY SUGGESTIONS?
