Question for all you type R gurus.
Old Oct 29, 2009 | 08:43 AM
ported13b's Avatar
Default Question for all you type R gurus.
OK now we have the 2 type r lug combos the 4x114 and the 5x114 now my question to you is the bearing length on the 4x114 the same as 5x114. i ask because if any of you have tried the normal integra bearing on the inside of the rear hub is roughly 10mm smaller than the type r so the bearing carrier on the type r is a bit longer which makes bolting up the 5 lug rear hub to the normal integra rear lower arm pretty much impossible. any input at all would be really helpful.
thank you,
Derick
Old Oct 29, 2009 | 09:24 AM
wannabe_itr's Avatar
Default Re: Question for all you type R gurus.
if its 36mm its wider if its 32 its the same
Old Oct 29, 2009 | 09:44 AM
ported13b's Avatar
correct me if im wrong but i thought the whole 36mm and 32mm only pertained the the front axles im talking about the rear.
chinolal
Mar 14, 2010 11:00 AM
Mopedstud
Sep 2, 2009 12:45 PM
gldndrgn14
Suspension & Brakes
10
Jan 4, 2006 09:56 AM
