Brake or Axle problem?
Old Oct 28, 2009 | 10:06 PM
SamC's Avatar
Default Brake or Axle problem?
I have a 96 Accord Lx. There is a strange metal scrapping should when i was driving in the parking lot today. It was a cold day. The sound is happen when the car is in motion.
The scrapping sound also appears when the brake is not pressed.
But after driving for a while in the freeway, the sound it gone.
I wonder if it is because of the cold weather.
What are you thoughts?
Old Oct 28, 2009 | 11:54 PM
PilotOnDubs's Avatar
Default Re: Brake or Axle problem?
just take a quick look at your brake pads...they might be right at or above the sensors
Old Oct 29, 2009 | 08:25 PM
xhyperxshogunx's Avatar
sound like your brakes are out. the sound that you are hearing from the brake indicator scraping on the brake rotors.
Old Oct 29, 2009 | 08:49 PM
P_Adams's Avatar
Either one of two conditions may exist:
You may be to the point that the "wear sensors" on the brake pads are now hitting the rotor,
OR
The dust shield which sits just behind the rotor may have bent and is now scraping against the rotor as it rotates. Or you could have trapped a stone between the dust shield and the rotor.
P
CHu Chu
Jun 6, 2009 12:03 AM
c 2
Jan 29, 2008 07:06 PM
jond
Jun 27, 2003 01:03 PM
jjj784
Jan 25, 2003 09:35 AM
onyx00
Jan 19, 2002 06:37 PM
