fiberglass fenders
Old Oct 28, 2009 | 09:17 PM
kornkid21792's Avatar
Default fiberglass fenders
Soo i was thinking of getting some fiber glass fenders
i have a question though since they r not pre drilled do i just drill slowy and carefully to make holes for the bolts
thanks much
happy almost halloween
Old Oct 29, 2009 | 06:27 AM
prelude1897's Avatar
Default Re: fiberglass fenders
yes you just drill slowly through them. Start off with a small drill bit, and then work your way up to the correct size bit. I'd at least get a drill bit about half the size you need, then use the size that you need, but still take your time
Old Oct 29, 2009 | 07:35 AM
ok thanks alot^_^
Old Oct 29, 2009 | 12:03 PM
Apex1972's Avatar
I am gonna say it before nirVtec, do you really need fiberglass fenders?
Old Oct 29, 2009 | 12:17 PM
5SpdH22's Avatar
something gnarly
Active Streak: 30 Days
I didn't even use pilot holes, because I really didn't care about breaking mine. They held up fine.
Do you have stock ones that you're going to be getting rid of?
Old Oct 29, 2009 | 01:23 PM
cardudelude's Avatar
if you do...do it might use a little piece of tape and drill through the tape...you know the same way you drill wholes in the carbon fiber hoods...i dunno if you actually have to do that but its better safe then sorry right
Old Oct 29, 2009 | 03:23 PM
117's Avatar
117
What's the fitment like on these fenders? Are they generally the same width as OEM? I could really use some fenders that are 10mm to 20mm wider at the fender opening for wider front tires...
Old Oct 29, 2009 | 09:27 PM
lol i am geting them because 1 its my car im going to change the sytle to suit me.
2. my fenders are all sorts of screwed up and the z3 fenders are pretty cool looking to me.imo
and yes they fit like oem
idk how much wider they are
Old Oct 30, 2009 | 10:25 AM
NirVTEC's Avatar
This^^
G23accord11
Paint and Body
Jul 22, 2013 03:42 AM
maxogsr
Welding / Fabrication
Aug 10, 2011 06:56 AM
meric0786
Paint and Body
Mar 14, 2009 07:19 PM
Del Sol on Steroids
Jan 14, 2007 09:00 PM
Jared
Nov 3, 2003 09:33 PM
