power steering pump rebuild?
Old Oct 28, 2009 | 08:07 PM
98greensi's Avatar
Default power steering pump rebuild?
Hello has anyone rebuilt there power steering pump?, if so where did you get a rebuild kit from or what did you use?
the problem with mine is that i think the previous owner ran it low on fluid and pooched the seals if i rev the motor a bit it works fine, so i'm thinking the pump is just bypassing at low rpms but at higher rpm it had enough flow to work properly. I'm too cheap to buy a new one and don't know what pumps will fit b16a2 mounts
Thanks, Tom
Old Oct 29, 2009 | 07:05 AM
98greensi's Avatar
Default Re: power steering pump rebuild?
Bump
Old Oct 29, 2009 | 07:48 AM
deadazleep's Avatar
i replaced all the seals in mine one time because it was leaking like no ones business. Found the pump on www.hondaautomotiveparts.com and bought every seal in the pump then. Took the pump apart noting how it went together and replaced all the seals and it never leaked after that. The website has exploded view of the pump so that helps aswell.
Old Oct 29, 2009 | 12:12 PM
98greensi's Avatar
Thanks,
smcdonaldaz
Acura TSX
Dec 10, 2019 01:21 PM
highneo
Dec 23, 2008 12:31 PM
RedRacerCivic
Nov 28, 2004 11:59 AM
technine
Mar 20, 2003 08:06 AM
