Honda S2000 Honda S2000
5w-40 synthetic ok to run?
Old Oct 28, 2009 | 02:39 PM
EJAYATE's Avatar
I Deliver
Default 5w-40 synthetic ok to run?
I was told that 5w-40 was the oil for my s2000, and then cleary saw the cap labeled 10w-30 when I put it back on. Is this going to increase wear on the motor, should it be changed, car is going into storage in a week.
Old Oct 28, 2009 | 09:23 PM
ITRbroham's Avatar
shit post warrior
Default Re: 5w-40 synthetic ok to run?
You can use both no problem. 10w-30 is recommended and 5w-40 should be changed sooner due to the way it breaks down.
Old Oct 28, 2009 | 10:30 PM
SirStig's Avatar
just use the 10w30 IMO why mess with it?
Old Oct 29, 2009 | 04:42 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
because he prolly saved 50 cents by getting the other oil...
Old Oct 29, 2009 | 04:45 AM
SirStig's Avatar
mm tell ya what, come to me, i give ya two quarta
I never skip out on cheap stuff for my S
Old Oct 29, 2009 | 06:00 AM
JDogg's Avatar
i run amsoil signature series 0w30, its designed to replace 5w30 and 10w30. make a little extra power and lasts a long time.
Old Oct 29, 2009 | 09:42 AM
EJAYATE's Avatar
I Deliver
The stuff I put in was over $7.00 a quart, the intent was not to skimp. I went in to buy oil for my civic and asked the counter guy what was recommended for the S. I just bought this car and it didn't come with a manual or tonneau cover ...
The oil I put in is synthetic if that makes any difference.
Old Oct 29, 2009 | 10:34 AM
Tokyosmash!'s Avatar
Tickle-shits
Community Builder
Community Influencer
What did you buy? Shell Rotella?
Old Oct 29, 2009 | 11:08 AM
S2KILLA's Avatar
Thats your problem... you asked the guy at the counter... all you had to do was look at the oil cap... it says it right on there... or heres a novel idea, wait until you get home and make sure its the right one and then go back to the store at a later time...
Old Oct 29, 2009 | 01:49 PM
EJAYATE's Avatar
I Deliver
I used valvoline synpower. Sorry I didn't have the oil cap handy in my pocket to reference while at the store.
@jdogg do you still have the same oil pressure while running the 0w30?
Old Oct 29, 2009 | 01:57 PM
rice_classic's Avatar
Do you not have the owners manual?
10w-30 for normal changes. If the temperature gets below 0 degrees f in your area then you can use 5w-40.
5w-30 isn't going to cause any problems either.
Unless you're tracking your car alot or even racing it then there is NO cost/performance advantage in using expensive oils (like amsoil) espcially if you change your oil every 3k with Dino or 5k with SYN.
Old Oct 29, 2009 | 02:38 PM
Targa250R's Avatar
be professional
You'll be fine.
People think/read into oil way too much and end up throwing away a lot of money and time in doing so. The 5w-40 synthetic is an acceptable replacement for natural 10W-30. It's not a problem.
Old Oct 29, 2009 | 03:06 PM
JDogg's Avatar
i dont have an oil pressure guage, but the pressure comes up on startup just the same.
its what i ran in my built h22 and what i run in my integra. that oil goes 20k miles easy in my integra. I plan on 7500-10 on the S.. i put a good 100 miles a day on the car so tend to forget how quickly the miles come on. thats why i originally switched to amsoil was to extend the drain intervals.
plus, i beat the crap out of my cars, so good oil is a must.
Old Oct 29, 2009 | 09:28 PM
pettyboy69's Avatar
wow i dont think i could bring my self to not change my oil for that long i think it would kill me, i freak out if i go even 500 miles over the normal 3k to each his own i guess
Old Oct 30, 2009 | 02:59 AM
JDogg's Avatar
as its been said before, changing synthetics at 3k is tossing money away.
isnt the factory service interval for the s2000 5000 miles or so anyway?
Old Nov 1, 2009 | 05:13 PM
esean93's Avatar
yeah im changing my mobil1 at 5k no matter what anyone says.3k change interval is for regular oil.
Old Nov 1, 2009 | 05:44 PM
Wandaniers's Avatar
5w-40 full syn. is good for turbo applications if I was stock Id be running 10w-30 full syn or 5w-30 is good too depending on temps in the area.
Old May 6, 2010 | 11:03 AM
todorkondov's Avatar
Hello ...
sorry that run post in this topic, but did not want to run new to share my problem.
A few months ago I bought a s2k. Until now it was in the garage and car on fire once a week.
A few days ago I checked the oil level and the level was just below the minimum. This worried me, because I understand that the car spends oil.
Traveled 3,000 miles are for one year with MOTUL 5W40.
Please tell me what to do? The car drives very aggressively. I want to know Is this normal? To lower oil? To change it to another?
Please help!
Sorry for my bad English
The car is 135 000miles
Old May 6, 2010 | 11:53 AM
Targa250R's Avatar
be professional
Originally Posted by todorkondov
Hello ...
Please help!
It's normal for an S2000 to burn oil. It sounds like your engine used about a quart of oil over 3000 miles, which is normal and acceptable. You should get into the habit of checking your oil level more often and topping it off as needed. It's not a problem for an engine to consume a minor amount of oil, but it's a big problem to run the engine low on oil. I've found that the lower you allow the oil level to drop, the faster it will burn off.
Old May 6, 2010 | 01:36 PM
bigmacnfries's Avatar
"car on fire once a week" - there's your problem right there.
Old May 9, 2010 | 03:22 AM
How about drive with Mobil 10W40 full synthetic. My car is 130,000 miles and drive more aggressively. You all will be that kind of oil for my engine
Old May 10, 2010 | 05:38 AM
White Smoke's Avatar
i my honda
Global Mod
You will be fine, no need to change the oil. Just switch it to 10w30 at your next change interval.
Old May 10, 2010 | 06:24 AM
EJAYATE's Avatar
I Deliver
Went with 10w30 royal purp this time. Valves are alot more quiet.
Old May 11, 2010 | 08:58 PM
andross85's Avatar
anyone tried motul engine oil? sounds like a race car oil
which series should I use?
Zebra
Honda Civic (2006 - 2015)
Mar 8, 2011 07:55 AM
hoffmanb16
14
Sep 27, 2009 11:30 AM
jdmjunkie562
Apr 17, 2009 09:02 PM
driftwithme
Apr 17, 2007 07:35 PM
Seks
Oct 24, 2002 02:15 PM
