Removing B-series tranny same as D-series?
I am removing my LS transmission and installing a S1 short geared B16 transmission. Will the B-series transmission come out throught the bottom like the D-series or do I need to pull the entire swap out?
I am thinking it will drop out but it looks pretty tight.
im pretty sure if u use a jack under the motor side and a jack under the tranny side u should be able to tilt it and umm....shimmy it off and drop it.
