cel 8 and 22
Old Oct 28, 2009 | 09:33 AM
kirchnera's Avatar
New User
Default cel 8 and 22
recently bought a 92 prelude with h22 vtec.(first honda) supposedly all stock besides intake and headers. when i bought it had cel for knock sensor. put new one in and code went away. but now have cel 8 and 22. was going to check timing and see if its on for code 22(tdc sensor). if not should i get a new distributor??
and for code 8,(oil is full) i found the vtec oil pressure switch. and there is two wires yellow and black coming out of it, and they look new. (wondering if someone before tried fixing it?. is there away to check continuity with the key on acc? or just go buy a new sensor? were does the wires goto. havent had much time to look and follow the wires. im guessing black is a ground, but both yellow and black wires go thru the firewall
also i found 92 preludes didnt come with h22 vtec? didnt realize this when i bought the car. could the car be like a 1992 and a half and have vtec? or swapped?
thanks alot.
Old Oct 28, 2009 | 04:35 PM
thiskid0001's Avatar
Default Re: cel 8 and 22
look in faq cel 22 is vtec pressure and 8 is u can look it up
https://honda-tech.com/forums/honda-prelude-4/diy-diagnose-check-engine-lights-4th-gen-prelude-2495089/
Old Oct 29, 2009 | 05:43 PM
Remiss's Avatar
thx thiskid0001 i forgot to add 22 = vtec pressure in my faq
-8 is TDC POSITION (TDC SENSOR)
-pretty sure all 92 preludes arnt vtec correct me if i am wrong
-the oil pressure wire from the vtec solenoide connect directly to the ecu
LS Turbo300
Aug 23, 2012 04:47 AM
brandynEG
Jun 28, 2012 06:23 PM
EdSales
Jul 16, 2009 09:30 PM
hondaman156
Nov 12, 2006 06:11 PM
