Suspension & Brakes Theory, alignment, spring rates....
converting rear drums
Old Oct 28, 2009 | 08:12 AM
wlp2nd's Avatar
New User
Default converting rear drums
I have a 93 honda civic dx coupe ... my question is this: how can I convert my rear drums to disc without going to an Integra system ?? Is there a conversion kit ...
thnx,
will
Old Nov 2, 2009 | 03:14 PM
roastbeefrichie's Avatar
Default Re: converting rear drums
scarebird.com makes a bracket where you remove your drums and bolt-on rear disc calipers
go to their website & scroll all the way down...they're $85 for the adapter brackets
PARTS LIST
scarebird adapter brackets
rear disc calipers (stamped 7CLP13S), found on 90-00 civics w/ rear disc & 90-01 integra
rear disc brake hoses (your drum hoses are too short) *use a flared wrench
9.4" rear disc rotors
integra e-brake cables
non-abs valve prop (will work on drum prop too since most of your braking is done with your front brakes)
brake fluid
bleed your brakes
here's a write-up found on turbod16.com
http://pollito.no-ip.com/turbod16/vi...p?f=17&t=42163
eg8ynot
Nov 6, 2008 04:43 PM
SkyliteCustomz
Jun 28, 2007 03:59 PM
Solscud007
May 27, 2004 07:39 PM
