f22a tranny to f23a1 block?
Old Oct 28, 2009 | 07:47 AM
F23A11990Accord's Avatar
Icon2 f22a tranny to f23a1 block?
for the past couple of days i have been doing research and trying to get the right info and if i have to keep track of the answers im hearing a equal amout of yes and no so im trying to take the best advice i can get.. ok here is the issue..
i bought a car that has a F23A1 Automatic Vtec engine in it and the transmission is no longer engaging in the car. i have called junk jards and various jdm part suppliers and what i am hearing is that i can get the f22a vtec tranny and use it with my f23a1 motor i wanna know if that is possible the other thing that ive heard is that i can use an h22a tranny and that too will work with my vtec accord. so i called around trying to find out more and one guy says yes and another at a different company says no i know that there are people here who are very car oriented please help me get to the bottom of this because i dont wanna buy the wrong transmission for my car
i know the best thing i can probably do is buy the f23a1 tranny and not have to worry about problems arising but if i can get a saying as to which one will work i will gladly appreciate the help as the f23 tranny are very scarce in florida and also expensive.
Old Oct 28, 2009 | 08:20 AM
hondamark35's Avatar
Default Re: f22a tranny to f23a1 block?
without comparing two side by side i couldn't say for sure that anything but the F23 trans will work with the F23.
i feel strongly that any F-series transmission should bolt up to the motor... but mounts, axles and wiring/ECU may or may not be compatable.
one thing that should narrow it down, you'll need to use an OBD-II compatable transmission. 96 or later.
once you find what is and isn't compatable, post it up. i'm sure you're aware of the lack of available knowledge on this subject.
Toallhisdoom
Apr 6, 2011 10:19 AM
96civic808
Sep 30, 2009 07:06 AM
alb_accord
Apr 20, 2004 12:30 PM
hybridcrx
Feb 28, 2002 04:38 PM
