GSR swap in del sol, Mounts?
Hi, i've looked around and found that i cannot clearly tell if i will need new mounts for me to swap a GSR motor into my 1993 del sol. I already have HASport billet aluminum solid motor mounts for the car, but the were on the D series that was in it. But then i look at getting swap mounts and some sites have 94-01 Integra, 92-95 civic....listing them together meaning they are the same? Please help, i just need a clear answer that will tell me for sure if i need to get new mounts or if the ones i have will work.
Thanks in advance for the help.
the del sol had a 2 bolt offset drivers mount while the integra had a 3 bolt drivers mount
I have the just the stock replacement kit for 92-95 civic/93-97 del sol/94-01 Integra, and the driver side mount is only the 2 bolt, but i'm pretty sure the GSR i'm swapping in has 2 bolts also. i was more worried about placement of the engine with the axles and what not.
Another question though- instead of getting swap axles, can i just take them apart and the knuckles/joint and then put the del sol -> hub side on and the Integra -> trans parts together, is there any problems with doing that?
you CAN use your stock D-series mounts, they are weaker than B series mounts though, it is recommended that you switch to B series mounts to install a B series engine into the del sol.
I am not familiar with the hasports, if they mount up then Id say your probably totally ok using them
okay thank you, that is all i needed to know. I actually have the solid motor mounts for the d-series, so i'm thinking they'll be okay for the d series swap.
90civichb
Jun 5, 2004 04:13 AM
bluedelsol
Jun 3, 2003 06:14 PM
