Honda S2000 Honda S2000
Another Tire Size and Rim Size Question
Old Oct 27, 2009 | 11:02 PM
sup3rd's Avatar
Default Another Tire Size and Rim Size Question
I've searched and I found a link leading to s2ki about wheel sizes. But I want to find out if there are people who have the same rim sizes as I do and what tires sizes they're running. I tried searching, but it's difficult to find a question exactly like the one I have.
So I just picked up some BBS 17x7.5 +45
Now I am confused about which tires sizes I should get since the s2k is staggered and I've heard of people running wider tires in the rear anyways.
So which tires does Honda-Tech run for 17x7.5 +45?
Thanks for your time
Old Oct 28, 2009 | 01:03 PM
sup3rd's Avatar
Default Re: Another Tire Size and Rim Size Question
bump, help a noob out please
Old Oct 28, 2009 | 01:08 PM
N_Vigz's Avatar
depends on the look your going for and ride height.
if it was me i'd go 205/45 225/40 since i would wanna go as low as possible.
Old Oct 28, 2009 | 03:00 PM
sup3rd's Avatar
I see I see. is the rear suppose to have a lower profile size or is that just for dumping it?
According to the chart on s2ki
http://www.s2ki.com/forums/index.php?showtopic=342793
For the front:
205 tires: +43 offset minimum (6.5� to 7.5� wide wheel)
215 tires: +48 offset minimum (7.0� to 8.0� wide wheel)
225 tires: +53 offset minimum (7.0� to 8.0� wide wheel)
235 tires: +58 offset minimum (7.5� to 8.5� wide wheel)
245 tires: +63 offset minimum (7.5� to 8.5� wide wheel)
For the rear:
235 tires: +40 offset minimum (7.5� to 8.5� wide wheel)
245 tires: +45 offset minimum (7.5� to 9.0� wide wheel)
255 tires: +50 offset minimum (8.0� to 9.5� wide wheel)
265 tires: +55 offset minimum (8.5� to 9.5� wide wheel)
275 tires: +60 offset minimum (9.0� to 10.0� wide wheel)
285 tires: +65 offset minimum (9.0� to 10.0� wide wheel)
Would it be all right to run 205/45 in the front and 235/45 for the rear?
Being 17x7.5 +45 it's not staggered. so is it really all right to run wider tires on the rear rims?
Old Oct 28, 2009 | 03:04 PM
4doorH22's Avatar
So you've got 4 x 17x7.5 +45?
I'm not sure about the front, but you might be able to run the OEM AP2 tire size of 215/45-17 F and 245/40-17 R, but with those sizes the front (according to Tirerack) usually calls for an offset around 48 and rear wheel width of 8 to 8.5" - though you should be fine with 7.5".
Old Oct 28, 2009 | 03:13 PM
4doorH22's Avatar
Sure, run wider on the rear. You want to keep the radius/diameter of your tires the same as stock so the ABS computer doesn't think there's something wrong and your speedo isn't too far off. Once you settle on the width you want, you should choose a profile (aka aspect ratio: it's the percentage of the tire's with) that makes the new tire's total radius equal to the stock tire's radius. Here are some tire size calculators you can use:
http://www.1010tires.com/tiresizecalculator.asp
http://www.miata.net/garage/tirecalc.html
Old Oct 28, 2009 | 04:31 PM
sup3rd's Avatar
oh wow I totally forgot about that site. Thanks a lot for your help! :beer
Old Oct 28, 2009 | 08:11 PM
esoterEK..'s Avatar
though ure rim widths are kind of weak..
Old Oct 28, 2009 | 10:58 PM
sup3rd's Avatar
aw they took out the beer icon!
yeah they kinda weak, but I got them for a good price
Old Oct 29, 2009 | 04:41 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
no you just forgot to put a : at the end of beer...
ohhh and 7.5's are way small for the rear IMO... if you put a 245 on its gonna look like the tire is bulging out...
Old Oct 29, 2009 | 05:13 AM
brandonS2k's Avatar
go for 8.5 in the rear then the 245's would be good
Old Oct 29, 2009 | 08:39 AM
4doorH22's Avatar
What size are your RFP1s? I got the 17x8 RFP1s (snow tires) from Tirerack for the rear because they said the 17x9 (17x8.5 in the recommended offset not available) would require fender rolling. Anyways, I've got 245s on 17x8's and they don't seem to bulge at all, but on 17x7.5s they might. To the OP, if you're worried about the fit, you're original choice of 205 F 235 R would be good, but I think you'd want 205/45 F 235/40 R to closer match the stock radius.
Old Oct 29, 2009 | 09:44 AM
brandonS2k's Avatar
mine are 17x8 17x9 +45 all around. More than likely I'll be doing 225/45 up front 255/40 in the rear. I'm stock ride height and will be running the uk spec alignment so I dont think i'll have to roll the fenders. But since Im wanting to go lower in the future I might go ahead and roll the fenders and relocate the bumper tab anyway just so I can already have it done.
Old Oct 29, 2009 | 11:36 AM
sup3rd's Avatar
Thanks man, that's what i figured too.
yeah the wheels are pretty skinny and nonstaggered but i got them for a great price!
's for everyone!!
Old Oct 29, 2009 | 11:54 AM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
the rears are gonna need rolling for 17x9 +45 unless you keep it at stock ride height. i have the same wheel specs and once had UK spec too before i went more agressive. oh and plenty of room for 17x8 +45 with 225 without a roll.
88 EF Hatch
Mar 12, 2010 09:42 AM
i-VTEC_DOHC
Honda Civic (2006 - 2015)
40
Dec 10, 2009 08:44 PM
IntegraBoy04
Sep 26, 2003 02:22 PM
Ex-ITR5874
Jan 13, 2003 06:13 AM
MintyDip
Jul 25, 2002 02:27 PM
