Azenis wear after 2000 street miles and 4/5 autocrosses
Old Aug 30, 2002 | 09:48 AM
HondaRcB's Avatar
Default Azenis wear after 2000 street miles and 4/5 autocrosses
Did some work on the R yesterday including new plugs and changing the oil and also went ahead and rotated the tires. Before the pictures let me tell you I'm not a very aggressive driver on the street and don't kill my tires. However the tires do have 4 or 5 autocrosses on them, most of which were in pretty extream heat. NOw for the pics. The links under each pic are for a HUGE version of the same pic.
Drivers side tires
http://www.imagestation.com/picture/...c.jpg.orig.jpg
Drivers side tread
http://www.imagestation.com/picture/...4.jpg.orig.jpg
Drivers side front
http://www.imagestation.com/picture/...9.jpg.orig.jpg
Drivers side rear
http://www.imagestation.com/picture/...d.jpg.orig.jpg
Passenger side tires
http://www.imagestation.com/picture/...a.jpg.orig.jpg
Passenger side tread
http://www.imagestation.com/picture/...e.jpg.orig.jpg
Passenger side front
Passenger side rear
http://www.imagestation.com/picture/...5.jpg.orig.jpg
Also the rubber buildup you can see on the inside of the rear tires was picked up from a autocross held at a local oval track, and just hadn't come off the tires yet. After rotating the rears to the front the extra tread depth was evident making the car feel a little more twitchy, but I've gotten used to it now and can barely, if at all, tell the difference.
Old Aug 30, 2002 | 09:51 AM
D's Avatar
D
Default Re: Azenis wear after 2000 street miles and 4/5 autocrosses (HondaRcB)
i should show you mine with ~13k miles on them...
Old Aug 30, 2002 | 10:22 AM
HondaRcB's Avatar
Default Re: Azenis wear after 2000 street miles and 4/5 autocrosses (D)
Man I can imagine, I'd be surprised if I get 6-8k out of these Still love em though.
Old Aug 30, 2002 | 10:48 AM
Fuminsho's Avatar
not bad
Old Aug 30, 2002 | 11:02 AM
05 600RR's Avatar
Default Re: Azenis wear after 2000 street miles and 4/5 autocrosses (Fuminsho)
They are in better shape than mine are in. I checked my alignment the other day and found out the place that aligned it f'd it all up. I had almost 2.5 degress negative tow. I ate over half my tires in 1000 miles.
Stupid alignment shop, what were they thinking
Old Aug 30, 2002 | 12:03 PM
JDM_ITR's Avatar
Default Re: Azenis wear after 2000 street miles and 4/5 autocrosses (itr 01-0492)
they didnt print out a sheet to show you wat your toe was when u aligned it?
Old Aug 30, 2002 | 04:31 PM
05 600RR's Avatar
Default Re: Azenis wear after 2000 street miles and 4/5 autocrosses (JDM_ITR)
It was an alignment shop that we used to use. They didn't charge me for the alignment so they didn't give me a sheet on it. Needless to say we now have our own alignment rack and do our own alignments now.
TonyRomo
Jun 5, 2008 08:21 AM
RealTypeR2
Oct 6, 2006 12:02 PM
nsxtasy
Sep 2, 2006 07:39 AM
Cypher0117
11
May 5, 2005 05:44 PM
itrsport.com
Aug 8, 2003 10:44 AM
