FS: NJ Used SX 18201 Fuel Pump w/ 41001 Fuel Filter
Old Oct 27, 2009 | 05:15 PM
KTULU990's Avatar
Default FS: NJ Used SX 18201 Fuel Pump w/ 41001 Fuel Filter
I have a used SX 18201 Fuel Pump w/ 41001 Fuel Filter. Worked great before I took it off the car a few months back. $250 obo PRICE DROP $225 obo
The 18201/18203 EFI and Carburetted Alcohol Compatible Electric Fuel Pump
Here is some info on it:
Aerospace Engineered and Manufactured
Supports up to 1,300 HP
Maximum Tuning Flexibility
Compact & Lightweight Designs
Quick & Easy to Install
The 18201 Electric Fuel Pump is the industry leader in it's class. Designed for both EFI and carburetted applications, the 18201 can support up to 1500 HP with a single pump. Flow tested to deliver 2.4 GPM at 0 PSI to 0.7 GPM at 90 PSI at 12 volts. The 18201 is well suited for normally carburetted and blow through systems, and is excellent for mid range domestic and import applications. It also passes UL Standards for Coast Guard Approval in marine applications.
The industry leader in it's class. Designed for both EFI and carburetted applications, the 18203 can support up to 1,300 HP with a single pump. Flow tested to deliver 2.4 GPM at 0 PSI to 0.7 GPM at 90 PSI at 12 volts. The 18203 is well suited for normally carburetted and blow through systems, and is excellent for mid range domestic and import applications. It also passes UL Standards for Coast Guard Approval for use in marine applications.
Make no mistake about it, SX Performance™ has created the most reliable fuel pump in the world today that handles high pressure/high volume fuel systems up to 1,300 HP at 45 PSI. So no matter what you're running, our pump alone lets you switch between carburetted and fuel injected systems simply by changing the regulator.
When a thousandth of a second can win a race, you need a total fuel system with consistent and reliable performance, run after run. You need a manufacturer with decades of proven flow and pressure experience.
You need SX Performance™.
Old Oct 28, 2009 | 10:32 AM
KTULU990's Avatar
Default Re: FS: NJ Used SX 18201 Fuel Pump w/ 41001 Fuel Filter
ttt
Old Oct 30, 2009 | 03:24 PM
KTULU990's Avatar
ttt
Old Nov 1, 2009 | 04:15 PM
KTULU990's Avatar
ttt
Old Nov 3, 2009 | 12:23 PM
KTULU990's Avatar
ttt
Old Nov 5, 2009 | 11:59 AM
KTULU990's Avatar
ttt
Old Nov 9, 2009 | 11:32 AM
KTULU990's Avatar
ttt
Old Nov 10, 2009 | 05:26 PM
KTULU990's Avatar
ttt
Old Nov 11, 2009 | 05:44 PM
KTULU990's Avatar
ttt
Old Nov 15, 2009 | 12:17 PM
KTULU990's Avatar
ttt
Old Nov 16, 2009 | 01:29 PM
KTULU990's Avatar
ttt
Old Nov 17, 2009 | 03:25 PM
KTULU990's Avatar
ttt
Old Nov 19, 2009 | 06:25 PM
KTULU990's Avatar
ttt
Old Nov 22, 2009 | 05:32 PM
KTULU990's Avatar
ttt
Old Nov 23, 2009 | 08:02 PM
KTULU990's Avatar
ttt
Old Nov 24, 2009 | 05:44 PM
KTULU990's Avatar
ttt
Old Dec 1, 2009 | 11:22 AM
KTULU990's Avatar
ttt
Old Dec 3, 2009 | 11:21 AM
KTULU990's Avatar
ttt
Old Dec 8, 2009 | 04:37 PM
KTULU990's Avatar
ttt
Old Jan 2, 2010 | 08:39 AM
KTULU990's Avatar
ttt
Old Jan 22, 2010 | 09:33 AM
KTULU990's Avatar
ttt
Old Feb 2, 2010 | 09:03 AM
KTULU990's Avatar
ttt
Obama
Texas -OK -LA (Sales)
Oct 28, 2010 12:18 PM
Obama
Aug 12, 2010 01:22 PM
jakem200
Apr 9, 2009 09:53 AM
Huee
Mar 12, 2004 10:01 PM
