Best springs?
Old Oct 27, 2009 | 03:27 PM
agavenda30's Avatar
Default Best springs?
I just got a 95 integra and i think that the springs that are on there are getting old because my tires scrape everytime i hit a bump, even if its not that big, and my rims and tires are pretty small 195/55/15. What are the best brand springs to get but still in reasonable price?
Old Oct 27, 2009 | 03:44 PM
TunerN00b's Avatar
Default Re: Best springs?
195/55-15 is the correct (and original) tire size for Integras on 15" wheels.
If your tires scrape, and you have stock wheels, you have much more serious issues than worn out springs (which don't really ever go bad). If you have aftermarket wheels, you probably have the wrong width and/or offset for the car.
Old Oct 27, 2009 | 04:46 PM
Maluko's Avatar
a stock 4x4 integra shouldnt rub tire unless the car is lowered. if this is the case, raise your car back to stock height.
Old Oct 27, 2009 | 04:48 PM
Maluko's Avatar
if youre not referring to rubbing tire with fender. dont pay my comment any attention
Old Oct 27, 2009 | 08:22 PM
STRDAGEY88's Avatar
Do you have any pics of your riding height? Your shocks might be blown if its bottoming out every time you hit a bump. Or your fender liner could have come loose and is rubbing on your tires, this happened to me and it would rub when i took right turns
Old Oct 28, 2009 | 11:35 AM
TunerN00b's Avatar
You have the wrong offset wheels. Its obvious from the picture. Too low of an offset.
To fix the rubbing, you'll have to roll (and possibly pull) the fenders, or get wheels that fit correctly.
zach1288
12
Jul 20, 2009 09:26 AM
Acura_DreamiN
Feb 18, 2009 11:26 PM
ware
Suspension & Brakes
10
Jan 12, 2009 12:20 PM
93formula
Jun 6, 2007 08:29 AM
MDPL8706
Aug 8, 2006 02:34 PM
