Transmission & Drivetrain Gearboxes, Differentials, Clutches
Is My DC2 Tranny F$#@ed Up..
Old Oct 27, 2009 | 02:36 PM
royc508's Avatar
Default Is My DC2 Tranny F$#@ed Up..
Sup HT. A couple of weeks ago i smashed up the front end of my Integra. The car definately will not drive due to a broken axle and i think a bent tie rod end. During the accident i think i destoryed my transmission. I have one side of my car up on a jack and when i rev the engine in neutral my speedometer starts moving along with the RPM gauge. Does this mean i need a new transmission? I was thinking about just buying a shell cause my CEL is on due to a missing O2 sensor. Do you guys think its worth the fix or should i just buy a shell?
Old Oct 27, 2009 | 02:46 PM
night's Avatar
Default Re: Is My DC2 Tranny F$#@ed Up..
nuetral can drag some. if the tranny housing is ok, the trans is most likely ok.
unless your wreck slid sideways jamming the axle into the trans i wouldn't worry about it.
Old Oct 27, 2009 | 02:56 PM
Aquafina's Avatar
Speedo is moving because a wheel is unloaded. Why would you buy a shell to fix an o2 problem?
Old Oct 28, 2009 | 06:42 PM
royc508's Avatar
The dude who had it before me hacked off one of the o2 sensors and did something to the wiring. He ended up welding something to the pipe. I was trying to ask around to see if its a easy fix but havent had any responses yet. As far as the tranny goes the casing definately looks in good shape but i done know if i destroyed my gears or not.
Old Oct 28, 2009 | 07:55 PM
Aquafina's Avatar
If the case isn't cracked the gears are fine (at least from the wreck).
Fixing the o2 is normal. Just pickup a Helms and get friendly with the wiring diagrams.
luckydogie
Honda CR-V & Element
Apr 6, 2014 09:32 AM
19Accord97
Jan 16, 2010 03:18 PM
josh564738291
Nov 2, 2007 07:15 PM
CRISIS
13
Apr 25, 2006 07:55 AM
