What is in between the alternator and the battery?
Old Oct 27, 2009 | 02:06 PM
Speed--Freak's Avatar
Default What is in between the alternator and the battery?
I just replaced the alternator. The car dies if I disconnect the battery. I'm getting 12.96v from the post on the alternator to a ground and I cleaned the battery connections.
My question is what could be keeping the alternator from charging the battery?
Old Oct 27, 2009 | 02:27 PM
efjones9's Avatar
Default Re: What is in between the alternator and the battery?
Why would u disconnect the batter while the car is runnin? Do u mean ur jumping it and it dies wen u disconnect the jumper cables?
Old Oct 27, 2009 | 03:26 PM
4drEF's Avatar
Keyboard Humorist
There is a heavy white wire that runs from alternator to the fuse box... and that runs through a fuse and to the battery.
Check your grounds and clean them up.
Inspect your wires especially where they open up to a connector or lug.
Water sometimes gets in through there and corrodes the wire.
Your alt should be putting out a full 14v so maybe it's a defective alternator (they aren't always perfect even though they are new). Bad wiring or ground could cause this.
BiG ChOr!Zo's Avatar
faulty alternator
now that is change that i can believe in...!!!
Old Oct 27, 2009 | 03:27 PM
crawfo661's Avatar
you should be able to run the vehical on just the alt. no real need for a battery other than starting
Old Oct 27, 2009 | 03:33 PM
Right, that's what I tried and it would just die (alternator was basically disconected from the car).
Old Oct 27, 2009 | 03:37 PM
I'm having bit of trouble finding where the white wire leads to.
I think it runs to the fuse block on the shock tower but I'm not positive.
Old Oct 27, 2009 | 03:47 PM
crawfo661's Avatar
if its wiried up as it should be it could just be bunk
Old Oct 27, 2009 | 03:48 PM
Tyson's Avatar
lemme gues.. you got the alternator from autozone?
Old Oct 27, 2009 | 03:50 PM
OK now your scaring me
Old Oct 27, 2009 | 03:53 PM
crawfo661's Avatar
yup u got a bunk one!!!!
Old Oct 27, 2009 | 04:09 PM
4drEF's Avatar
Keyboard Humorist
That's where it goes.
If you can test for output right at the alternator you should see 14V.
Guessing you will see that 12.6V again... and it's a bad alternator.
Old Oct 27, 2009 | 04:25 PM
OK,
I disconnected the white wire from the alternator and started it up.
I put the positive test lead on the post the white wire goes on and the black lead on the frame.
I only got 1.47v from it.
I'm guessing that it was back feeding from the battery before?
I'm sure this is getting very technical but does the green plug on the back of the alternator tell it to "turn on"? I just don't want to pull it back out just to find out it's something else.
Old Oct 27, 2009 | 09:45 PM
Tyson's Avatar
return the alternator to autozone if it does not produce 14.5V when operating normally. its very common to get a bad one from autozone. youre the second person in two days to come here wondering about a "new" alternator gone bad. it happens regularly with autozone alts.
Old Oct 28, 2009 | 06:52 PM
civicwagonman's Avatar
grounds good on the valvecover?
Old Jan 5, 2022 | 05:22 AM
HaydenMacfly's Avatar
Wait, what?! That can interfere with having signal to the alternator?! 😬
SpoonEk253
Jan 5, 2022 09:23 PM
Lance Baker
Honda CR-V & Element
Dec 5, 2021 06:55 PM
Corksil
12
Mar 1, 2018 03:52 PM
Annihilator
Oct 14, 2009 04:55 PM
nevin
Aug 11, 2003 09:59 AM
