ef wiring issues
Old Oct 27, 2009 | 12:31 PM
prime-R's Avatar
Default ef wiring issues
my friend gots a 1990 civic dx hatch with a jdm b16 swap,the harness is cut up,what harness can we use to replace it and have the car running good,or what harness can plug and play or if it needs mods
Old Oct 27, 2009 | 12:40 PM
ed4doorcivic's Avatar
Default Re: ef wiring issues
it needs the harness that is for that motor and ecu as well, unless y know sum1 that can make u a harness and wire direct. but im sure only b16 harness
Old Oct 27, 2009 | 01:35 PM
prime-R's Avatar
ive been hearing that i need to use the stock harness of the car and convert a couple stuff
Old Oct 27, 2009 | 06:28 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Don't listen to this ^^^ NOOB ^^^ ... just use the harness from YOUR CAR and add what is necessary to complete the DPFI to MPFI. ALL OF THESE QUESTIONS CAN BE ANSWERED IN THE FAQ... you NEED to learn how to SEARCH!!!
Old Oct 27, 2009 | 06:47 PM
crx_si-r's Avatar
depending on how knowledgeable you are with wiring. you can get another DX harness, convert to mpfi and add wires for vtec and knock sensor. or you can get an Si Engine and Dash Harness and add the missing vtec and knock sensor.
Or you can contact Rywire and ask them for a DX to Vtec wire conversion harness or DX to OBD1 vtec harness and call it a day
Old Oct 27, 2009 | 07:07 PM
1997 gsr's Avatar
off the top of your head how much would one of these harnesses cost?
Old Oct 27, 2009 | 08:30 PM
crx_si-r's Avatar
here is the link....
http://www.rywire.com/store/index.php
88-91 CRX HF/Si OBD0 VTEC Subharness $55.00
88-91 CRX/Civic DX/STD to d15z1 (VTEC-E) $340.00
88-91 CRX/Civic DX/STD to d16a6 (DPFI to MPFI) $160.00
88-91 CRX/Civic DX/STD to d16z6/d15b (OBD1 VTEC) $300.00
88-91 CRX/Civic DX/STD to DOHC ZC Conversion $160.00
88-91 CRX/Civic Si/Hf/Ex to d16z6/d15b (OBD1 VTEC) $190.00
88-91 CRX/Civic Si/Hf/Ex to DOHC ZC (OBD1) $165.00
OBD0 to OBD1 Distributor Adapter N/A
OBD0 to OBD1 ECU Conversion Harness $104.00
Si to DOHC ZC Distributor Adapter $35.00
but since i know most people wont bother to look on the page. here is capture of Ryan's prices. Ryan if you want me to remove it lmk.
Old Oct 27, 2009 | 08:32 PM
crx_si-r's Avatar
or you can go to the local junkyard find the si counterpart to your car. spend about an hour or so and remove the entire harness from the car and only pay about 30.00
thats what it cost me and i took the ENTIRE car harness from a 91 crx si. i even have a sunroof switch with oem harness for it, but no sunroof in my dx
Old Oct 28, 2009 | 04:11 AM
DO IT ON ALL FOURS
Bwahahahahaahahahhahahahahahahah!!! CRX S-IR you are waaayyyy too nice to these helpless people. You even took the time to post a screen shot of rywire.com... Now THAT is classic.
Old Oct 28, 2009 | 05:21 AM
crx_si-r's Avatar
cuz i know they arent gonna click on the link. i think most of the newbies on here are used to having things done for them.
Old Oct 28, 2009 | 08:21 AM
DO IT ON ALL FOURS
Well why would you feed into them then? They have to get off the teet sometime or another... Oh well... YAY for free post counts!!!
Old Oct 28, 2009 | 09:33 AM
prime-R's Avatar
Naw don't get it twisted,I know what needs to be done I just needed to confirm b4 I go buying things,its not my first swap or last but it is my first time messing with obdo I just wanted to separate the facts from fiction,read my second post indicates I knew I needed to use the dx harness
Old Oct 28, 2009 | 10:03 AM
prime-R's Avatar
Also the ecu is an ef si ecu can I stay with it or I would have to change
Old Oct 28, 2009 | 11:17 AM
DO IT ON ALL FOURS
See... you did not do your homework Little Johnny...USDM 88-91 CRX's and Civic's are OBD-0... YES THAT MEANS ALL OF THEM... so what are you trying to do again? Wait what's that? Go OBD-1 you say? Well then, what do you think the answer is?
Old Oct 28, 2009 | 12:01 PM
HAHAHA if u listen to this guy then u will end up being a piece of **** just like him, HAHAHA neversatisfied is a cocky **** talker! but hey that is what forums are for right, people giving what they MIGHT KNOW, and people who know and people that talk **** with **** in the mouth.
Old Oct 28, 2009 | 12:18 PM
crx_si-r's Avatar
Ef Si?? You mean an ed Si ecu or pm6. You are supposed to run an sir ecu such as a pw0 or pr3
Old Oct 28, 2009 | 12:21 PM
prime-R's Avatar
"See... you did not do your homework Little Johnny...USDM 88-91 CRX's and Civic's are OBD-0... YES THAT MEANS ALL OF THEM... so what are you trying to do again? Wait what's that? Go OBD-1 you say? Well then, what do you think the answer is?"
Lol again you stick your foot in your mouth,1st I never asked what it was,I know its obdo like I said apperantly you did understand its a crx ecu and what wait what is a crx obdo that's right,I asked if I should keep it or not since I have never heard of obdo being chipped or if it would be better to run a jumper harness and use a p28 buddy,
Don't get me wrong I thank you for the help even tho you don't answer non of the question but read before you post because then you'll be spending time taking your foot out your mouth
Old Oct 28, 2009 | 12:25 PM
crx_si-r's Avatar
Or if you want to do the obd1 you will need more items:
obd1 b16 distributor
4 wire o2 sensor
obd1 p30, obd1 pr3, chipped p28 or the hard to find p61
obd0 - obd1 adapter harness
Old Oct 28, 2009 | 12:28 PM
prime-R's Avatar
Thank you crx_si you actually answered my question,not like other people,im new to obdo not to honda,this isn't my first build,crx_si just to let you know I got the dx harness and tomorrow I start the dpfi to mpfi conversion
Old Oct 28, 2009 | 12:30 PM
hey dude post sum pics when u do the DP to Mp, i plan on doing it as soon as i get ahold of all the parts.
Old Oct 28, 2009 | 12:33 PM
prime-R's Avatar
Yeah I know about that,but that won't be for another month,for now ima use the pw0 ecu and stay obdo for now,my other civic needs to go under the knife so I just want to get this one going
Old Oct 28, 2009 | 12:44 PM
DO IT ON ALL FOURS
Thank you for paying attention to me. Also, I would rather be that then a dumbass like you.
Old Oct 28, 2009 | 12:49 PM
DO IT ON ALL FOURS
1.) Thank you for paying attention to me.
2.) OBD-0 can easily be chipped and tuned. (There are much more options and capabilities with OBD-1 though.)
3.) I would never go back on something I said. I know it all, just ask me.
4.) There I answered a question of yours.
Old Oct 28, 2009 | 12:54 PM
prime-R's Avatar
No prob ima double check the ecu and post the info,and I didn't know you could chip obd0 thank you for the info
Old Nov 1, 2009 | 02:54 PM
A-Man's Avatar
hey if i can jack this thread i also have some wiring dramas,
the story with my car is its a ef7 and it had a b18c converted into it, the b18c is missing and id like to put a zc back in. now the prob is my rear harness has been spliced to a dc2 harness has anyone got the pinouts or pics of the rear harness plugs i can see please, i cant seem to find any. the other thing im looking at is the drivers window has been cut to so id like to c where it connects back into the stock wiring harness. thanks guys
Timothy Yhtomit
Feb 26, 2019 02:25 PM
CRseXy
Jun 27, 2005 04:17 AM
89-ef
Feb 25, 2004 06:42 PM
98AccordEX
Aug 31, 2003 07:00 AM
