bad wheel bearing 97 civic with rear discs
Old Oct 27, 2009 | 10:09 AM
thisiskev's Avatar
Default bad wheel bearing 97 civic with rear discs
hey guys i have a 97 civic hatch that has rear discs in the back and the wheel bearing is bad. i was wondering if the wheel bearing is the same part for the 97 civic or if it would be different since it has the disc conversion off a gsr or 00 si not really sure since i bought the car that way.
Old Oct 27, 2009 | 11:37 AM
hentai_11's Avatar
Default Re: bad wheel bearing 97 civic with rear discs
Well obviously it cant be from a drum brake setup, and I believe its the same part number for integra and si rear disc trailing arms
Old Oct 29, 2009 | 06:38 PM
thisiskev's Avatar
ok the rear hub for a 97 civic is not the same oem part if it has rear discs. i needed an integra hub.
TheGreenOne3589
Jul 7, 2009 04:46 PM
blaak-crx
Aug 11, 2007 05:16 PM
:Andrew
Nov 3, 2006 08:45 AM
