FS:S13 Coupe.SR/Tomei/Blitz/silvia front **taking offers**
Bought the car from another member on here in July of 2008. Selling car now because I will be relocating for my job.
Description from old thread:
Here's what I've done to it:
Interior
-AEM UEGO Wideband o2 A/F Gauge
- Defi Boost Gauge
- Autometer Oil Pressure Gauge
Engine
-Freshly Rebuilt Motor. PM for Details Have Receipt for it.
-Fresh Fluids
-Rocker Arm Stoppers
Plan was to build up a 400-450 hp car, but plans changed as stated above.
The Bad:
-Stock Interior
-No carpets (planning on ordering new ones)
-No Radio (planning on ordering new one)
-HUD displays 0 mph (might be speed sensor, test cluster and it works)
Car will be sanded, buffed, and cleaned.
Will deliver for reasonable amount.
Price: 9500
Car is a 91 240sx SE ( full power everything w/ moonroof )
forgot to add. the car is a Southern car. and has Always been RUST FREE and has a clear title
DRIVETRAIN
-JDM SR20 aprrox. 45k
-Mild Wire tuck
-tomei 270 Cams
-Blitz BOV
-Blitz filter
-Koyo Aluminum radiator w/ dual slim fans
-XS power front mount intercooler
-Driveshaft shop 1 Peice aluminum driveshaft
-Blitz turbo timer
-Megan Stainless Manifold wrapped in header wrap
-Circuit Sports Coolant resevoir
-All Samco Hoses on motor
-Nismo radiator cap
-3 inch Stainless Megan downpipe
-3 inch full Megan stainless catback
-Engine damper
-Solid motor mounts
-Exedy clutch
-all 3 inch aluminim intercooler piping
SUSPENSION
-Megan racing full 32 way adjustable coilover with extended tophats and camber plates
-camber kit in the rear
-Ceasar Mahdi wheels 17x8 (f) 17x9 (r)
-Ichiba 10mm sacers in the front to clear the coilovers
-brand new BFGoodrich tires 100% tread
EXTERIOR
-full steel OEM Nissan silvia S13 front end conversion
-Dual REFLECTOR Glass headlights ( rare )
-Silvia K's front bumper with amber corners and turnsignals
-OEM silvia front grill assembly
-Hood is tilted up to clear the intercooler piping as best as possible
-Full brand new proffessional color change, was ( car still needs to be color sanded and buffed )
-OEM Silvia tails
currently looking for an OEM silvia rear wing but holes have rubber plugs in them
INTERIOR
-MOMO offset steering wheel
-Cursed OEM seat bolster tear on driver side
-OEM heads up display ( currently not working)
I'm sure theres are some things im forgetting as always. but this car really is a beautiful machine.
there is no hack work on this car at all. all work was done by all I-Car and ASE certified Technichains.
DRIVETRAIN
-Mild Wire tuck
-tomei 270 Cams
-Blitz BOV
-Blitz filter
-Blitz turbo timer
-Nismo radiator cap
-Engine damper
-Solid motor mounts
-Exedy clutch
SUSPENSION
EXTERIOR
-OEM Silvia tails
INTERIOR
Interior
- Defi Boost Gauge
Engine
-Fresh Fluids
The Bad:
-Stock Interior
Price: 9500
