What are the possible newer swaps for a 95 Accord V6???
Old Oct 27, 2009 | 06:51 AM
vche101's Avatar
Default What are the possible newer swaps for a 95 Accord V6???
I have a 95 Accord V6 and wondering what are the possible swaps that i could do? From what i researched, since its a V6 chasis doing a H, J or K series swap is lot of work. So, now im looking in to doing a newer Accord V6 Manual or Automatic swap. Any suggestions? Thanks in advance for the Help!!!
Old Oct 27, 2009 | 06:39 PM
PilotOnDubs's Avatar
Default Re: What are the possible newer swaps for a 95 Accord V6???
yeah i remember reading a honda tuning mag awhile back saying, that if you already have a v6 chassis, stick w/ a v6 set-up. dont go w/ a 4 cylinder motor, its just too much work/$/ and fabbing...
however, anythings possible if you are on an endless budget...
i think there was another honda tuning mag i read, that had a 98-02 v6 coupe and the guy swapped out the motor w/ a cl or tl motor i think w/ a 6 speed manual transmission...pretty sweet...
theres also a shop in arizona i think that put a odyssey v6 motor in an eg civic..so anything possible...
Old Oct 27, 2009 | 07:28 PM
YeuEmMaiMai's Avatar
since the J30a1 was used in the 3.0CL, any J motor will fit in there, you will need to get all the parts from the 3.0CL and mounts from the donor car that the engine came out of. You can do a cls-6 swap but that will cost you some big $$. as those are DIS motors and use an entirely different setup and a lot of wiring will have to be done to get it working right.
balu23
Jul 7, 2012 10:41 PM
morethanjake
Oct 1, 2001 06:28 PM
