Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
recommend exhaust for 07 civic ex sedan
Old Oct 26, 2009 | 10:02 PM
roseinsky's Avatar
New User
Default recommend exhaust for 07 civic ex sedan
hi I have 07 civic ex sedan, am looking for exhaust.
but I realized that I have only few options for my car.
so I am considering greddy ti-c or vibrant exhaust.
Also,I heard that the extension is needed for greddy ti-c, and somebody said that I should weld the extension. is it true?
please give me any recommendation for exhaust. thanks.
Old Oct 27, 2009 | 08:54 AM
100miles+'s Avatar
From: In Diamond Bar, CA Brake Boosting like a Mother Focker!
Default Re: recommend exhaust for 07 civic ex sedan
I would go with a 60mm because anthing bigger wont help unless your turbo'd. Yes welding it would be a good idea, usually with the sedans you need an extension if you have an exhaust for the Coupe. I am assuming your buying the exhaust for a coupe? If not then I would assume that the exhaust for the sedan should be the right size. Correct me if im wrong H/T.
Old Oct 27, 2009 | 10:04 AM
i-VTEC_DOHC's Avatar
greddy se ftmfw!!!
100miles+, yes you're right. you need the exhaust extension which greddy sells for like 60 bucks i tihnk, which is too much imo, but u can run the coupe exhaust on the sedan without the extension, but the tip of the muffler will be tucked underneath the bumper instead of sticking out like it normally does
VtecTURBOpanda
Oct 12, 2008 02:42 PM
kyeguy82
Jul 19, 2006 02:51 PM
burningwrek
Feb 25, 2005 06:59 AM
Roat
Jan 9, 2002 04:37 PM
