b18c1 type r rods and pistons!
i just purchased a 94 si hatch with a gsr swap the guy said it had itr pistons and rods just curious is this a good turbo setup if not what needs to be done for turbo also has si tranny act clutch and fidanza fly thx
type r piston are high compression. you gonna need to change the piston out to lower compression. if your goal is for some high crazy HP then invest into some good aftermarket pistons and rod. re-sleeve and bored out. if not then just sell your type r piston and buy some LS piston and just press them on the type r rod and you should be good for 9-10lb of boost for a few week til it blow. other then that. GL
^ LMFAO... I luv that last part, lol. If u just want medium HP (like 250 maybe 300) then just boost it to 6-8psi. If u want more than that ur gonna need lower CR forged rods and pistons and that may get u to 450 HP. No such thing as Type R rods either, just so u know.
fusion645
Jan 2, 2010 05:47 AM
dontcare61776
Jun 15, 2002 09:55 AM
