Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
ES1 EPS PROBLEM, HELP!!!!!!!
Old Oct 26, 2009 | 07:20 PM
brownspeed's Avatar
Default ES1 EPS PROBLEM, HELP!!!!!!!
i have an es1 sedan, whenever the car starts to warm up it sqeaks whenever i turn the steering wheel left or right, extremely annoying!! anyone ever experienced the same problem or know what 2 do??????????????
Old Oct 27, 2009 | 09:07 AM
theineffable's Avatar
Default Re: ES1 EPS PROBLEM, HELP!!!!!!!
where are you located? afaik, usdm es1's have hydrolic power steering.
as for the sound, can you pin point where it's coming from? is it really a squeak or a whine?
Old Oct 27, 2009 | 09:52 AM
It Wasn't Me's Avatar
Start with a belt inspection. Make sure it's in good condition, and has proper tension.
The deflection method will probably work best for you.
Apply a force of 22lbf and measure the deflection between the power steering pump pulley and the crankshaft pulley. If the belt is worn or damaged, replace it.
Deflection:
Used belt: 13.0 - 16.5 mm (0.51 - 0.65 in.)
New belt: 9.0 - 11.0 mm (0.35 - 0.43 in.)
Old Oct 27, 2009 | 06:19 PM
brownspeed's Avatar
im in jamaica, the car is japanese. its def. not from the steering box, but its coming from both sides of the wheels i think
tl44
Jan 31, 2011 05:05 PM
everlight44
May 4, 2009 07:08 PM
Inextricabledrvr
Mar 24, 2009 07:15 PM
matmcg
Apr 18, 2008 07:57 PM
Scharged00GsR
Jul 12, 2004 05:58 AM
