accord problem
Old Oct 26, 2009 | 03:16 PM
The Fallen's Avatar
New User
Default accord problem
i have a 93 accord with the F22. my problem is the number one piston has no power. cap an button are good. wires and plugs are brand new and i put a new injector in it. has 150psi in compression test. but when you pull the plug wire off there is no drop in idle and the car runs the same.
Old Oct 26, 2009 | 05:20 PM
P_Adams's Avatar
Default Re: accord problem
What color is the center electrode of the suspect cylinder's spark plug?
Does the center electrode look shiny/glazed? Any metallic specks noted?
While you're at it; with the plug out of the head, (and you've already looked at it) lay it on top of the valve cover with the wire attached, start the engine and confirm VISUALLY that you have spark.
*You MAY want to install a spare plug in it's place while you do this.
P
Old Oct 26, 2009 | 06:00 PM
$KAT3R_rc's Avatar
New User
nope spark plugs look good it has spark already took off spark plug and put it on the valve cover
Old Oct 28, 2009 | 03:17 PM
The Fallen's Avatar
New User
the plug has a good spark. an i re-gapped them while they where out. still has the same problem.
another thought. the fuel return vavle is right in front of that injector, could the fuel possibly be returning to the the tank and not going to the injector?
lxaccord51oxl
Sep 7, 2012 09:15 PM
deraj1986
Engine Management and Tuning
Jun 2, 2010 12:05 PM
UncleRay
May 18, 2007 12:03 PM
MestizoRacer310
Jul 25, 2006 12:49 PM
infiltrate2000
Aug 10, 2004 07:22 PM
