help with a leaking bead
Old Oct 26, 2009 | 01:29 PM
94 ls teg's Avatar
Default help with a leaking bead
I have 25x9x15 slicks and im tryin to mount them on rota slips 7.5x15. Im having trouble getting the bead to seal i have tried cleaning them and no luck. Would i be better running tubes or no tubes?
Old Oct 27, 2009 | 06:06 AM
94 ls teg's Avatar
Default Re: help with a leaking bead
asap
Old Oct 28, 2009 | 12:58 AM
Kaleb's Avatar
Is it a stretched tire? How old are the tires? Did you damage the bead when mounting them? Have you tired using bead sealer?
Old Oct 28, 2009 | 02:11 PM
94 ls teg's Avatar
anybody else that knows what they are talking about
Old Oct 29, 2009 | 06:51 AM
nsxtasy's Avatar
H-T Order of Merit
Stickied at the top of this forum is a topic:
Forum Rules and FAQ - READ BEFORE POSTING
It says:
Originally Posted by Forum Rules and FAQ - READ BEFORE POSTING
Rules
7. Bump once and if you still don't get the info you're looking for just let it die, don't bump it again. If you bump the topic a second time, the topic will be locked and you will lose points. Think about this - this means that if you use your single bump on your topic after an hour, when it's still at or near the top of the forum topic list anyway, it will be wasted when it doesn't accomplish anything for you.
Fittest224
Jun 5, 2012 07:44 PM
dc2_dustin!
Jun 19, 2011 05:26 PM
eagleclawracing
Jul 31, 2009 05:41 AM
ek9=]
Feb 13, 2009 12:03 AM
sky9
Jan 13, 2009 09:57 PM
