Where can I get the Beaks kit for ITR Sway Bar to fit EG?
Does Beaks have a website or an official distributor? I am looking to get this Beaks kit to fit an ITR Sway Bar onto a friends EG. Any info on the subject would be greatly appreciated. Thanks!
How long have you been a member???? What do you drive???? POS???
Please, do not tell me to do a search, unless it is for naked pics of your significant other. Thank you.
one thing to look out for tho. the bolts are 1/2 inch not 13mm like they claim. ok well i guess i will be flamed for saying that. however when i went to torque mine down i started to round the heads of the bolts using the 13mm so i switched to 1/2" and i never had that problem again. ok bring the flames i'm ready
so anyone experienced after installed the beak's kit with ITR sway bar on EG can't use the rear lower tie with it since the Beak's SRK plate block?
Beaks
Wil
[Modified by SLPR, 1:31 PM 8/30/2002]
I got one of these: http://www.beaksproducts.com/upgrade.html
Have'nt used it yet. But should work with Neuspeed bars and the like...
The neuspeed type bars already use a spacer bushing and longer control arm bolts. The Beaks upgrade kit supplies the same length bolts and did not appear (at the time on installing on my car) that they would have enough thread engaugement. I opted to go sans tie bar until I netted some longer bolts, another mounting adapter, or a different tie bar.
Other than that the product and install was top notch
[Modified by SLPR, 2:00 PM 8/30/2002]
mine is a reactive rear lower tie so not sure I can use this or not but I guess I have to give up my bar anyways since I am using HKS hiper catback and it will block my pipe near the muffler if you know how the hiper goes like
weaksauce.org
Northern California (Sales)
62
Mar 17, 2008 02:56 PM
Grocery Getter
Aug 2, 2002 07:24 AM
