FL LHT Performance Integra Type R Turbo
The time has to come to build a new Project.
This car is perfect in everyway.For those that don't know the specs on it, E-Mail me for detials.
450whp 93 octane, 550whp on race gas - 30+ mpg and runs like Honda built it,
Cover of Turbo magazine
http://www.turbomagazine.com/feature...e_r/index.html
FULLY built complete engine +drivetrain, JDM front w HIDs, Mega Alarm , TIEN, Aluminum exhaust ICE cold AC.
$25,500 complete or
$13,500 for the rolling chassis ,No motor, trans and turbo kit.
5th gear run, nothing special. Just showing midrange torque.
http://s89.photobucket.com/albums/k2...t=MOV08330.flv
http://s89.photobucket.com/albums/k2...t=FILE0026.flv
$25,500 complete or
You can choose between way the car sits right now for $25K or
I have a Geniune Spoon motor w' matching ecu and brand new OEM tranny for 19K ready to go
I will even through in a couple of copies of the magazine it was on the cover of.
Price drop $25,500.00
Thanks,
The car is detailed and ready to drive anywhere, You could drive it to California and enjoy great gas mileage and AC the whole way.
Here's a little about the engine.It was built to be very efficient, reliable and make lots of power.
It's the original C5 block GE sleeved to 84mm
9.5 to 1 CP Coated pistons ( Ballanced and No rattles)
Crower billet rods ( Blanaced)
Balanced crank by Endyn then Cryo treated
OEM bearings, Water pump, Endyn oil pump
Custom aluminum 6 quart oil pan with cooling fins
Full ported C5 head, Supertech valve train
Lightened and cyro treated rockers and Vtec assembly
Custom sheet aluminum manifold w' 68mm TB
STR cam gears, ITR cams
The engine runs and sounds like a stock B18C5, but revs a lot faster . on Pump gas the boost is 14 psi which it hits full boost by 4700 rpms and carries it all the way to 10,000rpms.I used a lot of little secrets I have aquired over the years to build this car.
More info to come.
More info to come.
Here's a couple of pictures with the Gun Metal JDM 16" wheels with new tires.
You choose which ones you want.
. A quick drive home after the wheel change
http://s89.photobucket.com/albums/k2...t=FILE0090.flv
