DA Integra trailing arms onto 99 Civic
Alright got some trailing arms yesterday off an integra. I have read about this swap and have 25% saying it doesnt fit and 75% saying it bolts right up. I also read that the main bushing is different. I need to get the center bushings for it, so which bushing do I use and where to get it. Is it safe to say that it is 100% bolt on except the brake lines and e-brake cable?
First off, does your car have ABS? If it does make sure you have ABS version DA spindles. ABS wasn't as common on DA's. Second, just replace the spindles and keep the existing civic trailing arms.
i have these da trailling arm on my 97 civic...You can bolt these to your car.You can use the stock da ebrake to.For the trailling arm bushing you can look for this how to
http://www.performanceforum.com/wesv...g/bushing.html
I just use this tip last week and it work like a charm
Function7
Suspension & Brakes
28
Jun 7, 2010 08:12 PM
MAD SCIENTIST
Mar 23, 2003 09:45 PM
