Timing/balance belts - 2002 accord 2.3 VTEC
Old Oct 25, 2009 | 09:44 AM
james02's Avatar
Default Timing/balance belts - 2002 accord 2.3 VTEC
Hi everyone,
I just purchased a used 2002 accord with the 2.3 VTEC engine. The car has 135K miles on it and I going to replace the timing belt to be on the safe side (i no record of its replacement). To my surprise there is another timing system - a balance system which is timing dependent.
Questions:
1) What are the balance shafts and how to they work?
2) Some recommend using only honda OEM parts for the timing belts and tension bearings. Is this really necessary or can I buy the upper end NAPA version or something reasonable off of alloemautoparts.com (where i have purchased Toyota timing belts in the past)?
3) Is it really necessary to replace the water pump at this time to or just a huge preventative maintenance thing.
Thanks for your time!
Old Oct 25, 2009 | 02:39 PM
fiveten's Avatar
Default Re: Timing/balance belts - 2002 accord 2.3 VTEC
Hi James02,
1) the two balance shafts help with low speed engine vibrations.
2) oem Honda belts are made by Gates Corp. so one would think that any belt manufacturer would be ok. I would pick a well known national brand if not Honda.
3) Do you want to take the timing belt off again in 30k miles when it goes bad? or wait another 105k miles?
good luck, let us know if you need help...
fiveten
Old Oct 25, 2009 | 04:29 PM
james02's Avatar
Hey fiveten, thanks alot for your help! I will let you know if I run into any snags.
Old Oct 25, 2009 | 07:36 PM
nus_dogg's Avatar
I'd go geniune; since, they tend to last longer than the non oe parts.
Water pump is a must in my book and who would want to take it back apart after half a year of timing belt replacement. GL man.
Old Oct 26, 2009 | 05:21 AM
TouringAccord's Avatar
H-T Order of Merit
dont forget oil seals
RA022626
Jul 2, 2015 10:39 AM
Gravymeister
26
Feb 21, 2014 04:28 PM
whiteboy9191
Mar 20, 2013 08:23 PM
faran
Oct 13, 2009 10:33 PM
Stew Pidasso
Jan 2, 2008 04:41 AM
