Coolant Temperature Sending Unit -2000 Honda Accord
Old Oct 25, 2009 | 06:27 AM
Choc-Thunder's Avatar
New User
Default Coolant Temperature Sending Unit -2000 Honda Accord
My temperature Gauge does not work at all on my 2000 Honda Accord. I was told that it is more than likely the Coolant temperature Sending Unit. Where is this located on a 2000 accord? I know that the ECU temp sensor is below the distributor cap but I do not see an input for another sensor. Is there only one on this model?
Old Oct 25, 2009 | 06:49 AM
HONDAPARTSMANMIKE's Avatar
Default Re: Coolant Temperature Sending Unit -2000 Honda Accord
i believe it only has the one sensor which controls both the gauge and the ecu
Old Oct 25, 2009 | 07:16 AM
New User
Thanks for the reply, I am going to try replacing this and see what happens.
Old Oct 25, 2009 | 02:56 PM
fiveten's Avatar
If you use a scan tool and can see the temp the ecu is reporting then the sensor is ok. the ecu sends the temp command to the gauge.
-Here is the temp gauge test.
fiveten
File Type: doc
younggun90
Sep 3, 2021 12:01 PM
Brett Lushia
Jan 19, 2019 05:37 AM
Jay Wang
Sep 22, 2018 10:57 PM
Kevins89notch
21
Mar 9, 2016 01:25 PM
maluhawk
Jun 10, 2013 01:24 AM
