Quick flywheel question....
Old Oct 25, 2009 | 06:22 AM
jdmtegrunner's Avatar
Default Quick flywheel question....
Ok here again.... Ok heres the thing. Is the JDM flywheel differ from the usdm? And whats different? Im already going to replace all flywheel clutch. But what I want to know is that. Because starter is grinding. maybe JDM flywheel+ USDM starter not good?
Old Oct 25, 2009 | 09:35 AM
Brice.Hayden's Avatar
Default Re: Quick flywheel question....
no they are not different. thats not your problem it must be something else. a flywheel is a flywheel regardless of what country it is from.
Old Oct 25, 2009 | 10:37 AM
Mindgamez's Avatar
If the starter is grinding its not shimmed right. Go get a new one before it destroys more!
Old Oct 25, 2009 | 03:42 PM
xero_xero's Avatar
Pull the starter and see if the bendix is shreaded or any signs or grinding. THEN check every inch of your flywheel if your having problems. there may be parts of the flyweel that are damaged.
Old Oct 25, 2009 | 04:38 PM
Micha's Avatar
FAILWGN
Make sure your starter is bolted all the way down.
wakaranai
17
Sep 14, 2016 07:02 PM
Andyb22g
Nov 22, 2004 03:30 PM
94si94cx
Aug 5, 2003 06:56 PM
MrBui
Dec 23, 2002 10:29 AM
lilcasino
Aug 4, 2002 08:25 AM
