About slicks, and sizes, what you could recomend for me? help
Old Oct 25, 2009 | 02:20 AM
RadekSkylark's Avatar
Default About slicks, and sizes, what you could recomend for me? help
What is most important of slick parameters? is it widht? or total diameter? i just dont know, what to do now i got a 1994 civic, witho stock d15b2 on 0.5bar, and, Iam building d16z6 bottom end, with eagles/vitaras and so on...
but i got front brake discs from VTi, minimum wheel requirment 14"... so, there is no slicks, for 14" wheels, so I probobly need 15"? and what sizes, I have no drop on front, but maybe i will have something about 1inch... now I have something about 160whp, and with d16 build engine for start planing something about 270whp... so, what would be the best solution for me? I was thinking of M/H 23/8.5-15, would it be good? pliz help guys Thanks a lot
Old Oct 25, 2009 | 08:33 AM
RootBur's Avatar
Default Re: About slicks, and sizes, what you could recomend for me? help
I'd think those m&h 23's would be a good option.
Old Oct 25, 2009 | 08:37 AM
ptftw's Avatar
22x8x13 should be good for you.
Old Oct 25, 2009 | 12:30 PM
But how can I put on 13" wheels if minimum discs I can put on is 14" cause I got 260mm front disc brakes...??? swapped from EG9 VTi.
Old Oct 25, 2009 | 12:46 PM
dester223's Avatar
There are wheels that you can run that will allow you to run 13" wheels on bigger brakes. Look up Lenso wheels.
23" slicks would probably be a better choice. You could run 22" slicks but if you plan on making more power, you would be better off with the 23s.
If you want to keep it simple and run a stock honda 15" wheel setup, you can easily get the MT 22x8x15s.
Old Oct 25, 2009 | 01:21 PM
OK, but would be 22/8-15 would be good for ~270whp? + it will be with my current turbo setup + not fully build engine, so, if something, I will plan to go bigger the 270whp's. and if i could get those Lenso 13" what would be the best drag slick to run? M/T or M/H? and sizes?
Old Oct 25, 2009 | 04:24 PM
Gkdc182's Avatar
22x8x13 +1
Old Oct 26, 2009 | 08:15 PM
ptftw's Avatar
you can use aero or diamond racing wheels too. they are cheap.
Old Oct 27, 2009 | 08:47 AM
welfarepc's Avatar
i ran 10s on my M&H 23x8x13's on lensos... if u went with 23s w/ a 15inch rim it would most likely work out for you
i am going to 24.5's next year, how ever, i plan to make more power and already had traction issues with the 23s
Old Oct 27, 2009 | 09:18 AM
DSRxCandyh2bEG's Avatar
Wheel spacers with extended wheel studs will also help with drag wheels. I have run Lenzos and Bogart Pro-4's with GSR brakes up front... The bogarts have an offset that works without spacers but the Lenzos needed a slight spacer...
project504
May 22, 2008 11:02 PM
caLiH22A
Jun 16, 2004 12:12 PM
NoClassic
May 7, 2004 12:49 PM
na4doorgsr
Jul 28, 2003 08:06 AM
PROFILES2000
Feb 13, 2002 09:57 AM
