2005 Honda Metropolitan
Old Oct 24, 2009 | 10:51 PM
Ep3 No.2's Avatar
Default 2005 Honda Metropolitan
so heres the deal, im selling my 05 honda metropolitan. motor has about 15xx miles chassis has about 89xx-9xxx miles. i converted the old slower pre 05 motor to the faster 06-up pcv model. the scooter ran solid with the old motor but would only top out at 35mph, with the mods i have on it now wth the combination of the fresh motor it will comfortably cruise at 45 mph and top out at about 50mph. i am also including spare roller weights so you can better fine tune the variator to your specific weight.
it is registered until oct 2009, the scooter it self has 75 dollars in back registration fees from dmv. i have the title as well but it is still under the original owners name. i attempted to register it but there is a fault in the paper work when i bought it from the previous owner (who never registered it). to complete the transfer of title you must contact the dealer who is located in benicia, ca (i can provide you with their number) if you dont want to go through the hastle this would be the perfect pit bike. i dont have the time to be running around to get the paper work signed. because of it im selling it with a bill of sale only. but i will provide you with all the paper work to complete the registration process
Engine:
2009 honda ruckus engine w/ pcv
2009 honda ruckus ecm and custom wiring harness
wrinkle black variator cover
Posh soft rev cdi
Polini Variator
6g/7g weights
blue clutch springs
nor tex exhaust
Magnetic oil drain bolt
diy intake w/ uni filter
Suspension:
ruckus rear wheel w/ kenda bopper
swift industries rear shock
hilo6 rear shock mounts
Aesthetics:
low gloss black paint job
yamaha virago side stand
xs bmx stem, dimension riser, thomson shim, problem silvers shim, daytona bars
ducati monster sequential rear tail light
kijima front turn signals, el12 relay
custom benen tow hook
spare parts not installed on the scooter:
jc lightened flywheel
ngk spark plug wire
spare uni intake filter
gtjd variator tool
5g, 5.5g, 6, 7, wieghts
stock bars, turn signals, gauges set up
stock turn signal, brake set up
stock motor mount
used stock belt
stock variator
stock drive face
stock clutch
stock ignition coil
stock turn signal relay
selling for $1400 delivered. ($300 non refundable deposit is required for delivery)
not willing to part out.
also willing to trade for the following:
a honda hatchback, 88-91 4dr civic
or some high quality 4x100 wheels
Old Oct 26, 2009 | 10:27 PM
Ep3 No.2's Avatar
Default Re: 2005 Honda Metropolitan
bizzump !
at this willing to trade for almost anything willing to trade for a k24 long block
4x100 wheels with tires or even some 5x114 wheels
Ponyboy
Acura NSX
28
Mar 9, 2009 04:40 AM
FGirl13
Honda Civic (2006 - 2015)
43
Apr 25, 2008 07:35 PM
nonvtec92
51
Oct 15, 2007 02:29 PM
Joel_MN
11
Sep 10, 2003 08:03 AM
