hondata s300
A computer with S300 installed, a basemap and a labtop to upload the basemap. If you want to do some street tuning you'll need a wideband. But that's about it.
PS the only H22 basemap on Hondatas software is for 440cc injectors, so you'll need someone to make you a basemap. Then to have it run right you'll need to install a wideband and street tune the A/F.
what exactly is the basemap and what is it for? thanks
I bought my S300 professionally installed in a P28 for $550 shipped; lucky find.
I'd suggest doing some reading before you go with S300. A basemap is ether an educated quess to get you in the general direction for your motor or it's a map from a different car. Ether way it needs to be tuned for your specific set up.
so u had a shop make u a basemap when they installed it?
wat car did u run it for?
ok so the smanager has preset maps under the calibrations and then from there u can just upload it to the ecu http://www.hondata.com/help/smanager/index.html, then work on it from there, right?
edit: ahhw which is exactly what i missed in the second post....
I bought a basemap from Motoxxman; I don't know if he's on here or not though. If I would of had a wideband and alittle more knowlege at the time, I would've just made a map myself.
I bought the P28/S300 off a guy on ************. It was brand new and came with a reciet. And I'm using it on my H22A 4th gen Prelude.
EDIT HT doesn't like Prelude Power lol
Exactly, a basemap is just a starting point and shouldn't be driven hard.
I know some tuners use a different map off of an integra for a starting point, but I'm not sure which one. I think it's a GSR map or something.
Do you have a wideband? I'd use the H22 map supplied with Smanage and tune the A/F.
How much did they charge you for a calibration? I have a map that I made myself, with a perfect airfuel of 13.1-13.3 from 4000rpm till 7500rpm.
^I think it was like $40, that was just a waste. The map was VERY rich and retarted. I removed 20% fuel just to get me in the ball park to actually start tuning it. What a waste of money.
I found a H22A7(Accord Type R) map on Hondata's forums, that I'm currently using; after some tuning of course. It has alot more timing than the basemap I bought(10ish* at WOT). My partial throttle power is MUCH better and their's noticably more power at WOT.
no i dont have a wideband, and yea i seen the stock b72 92-95 b18c gsr map so either that or stock b20?
