i have a slight problem
ok so head bolt is broken off down into the block and was wondering if anyone had any idea how to get it out so i can put a new head bolt in and get this car up and running again. help would be greatly appreciated thanks!
buy an extractor set such as a craftsmen set, hanson or irwin...they have reverse drill bits and you use them to drill the bolt in the center...(which is the hard part) then you use the extractor and remove the broken bolt..be patient w/ this...dont rush it...and good luck
just to give you an idea...
http://www.thetoolwarehouse.net/p-18...ial-11119.aspx
